Oil pump priming issue
Puting a rebuilt motor in and I have primed the oil system through the oil sending unit access hole. I had filled the oil filter prior to prime with fresh oil. After about 2 gallons into it oil started leaking from the turbo. Is this normal? I have a spare turbo that has a couple small dings on the cane from debris from original The engine failure Any help would be appreciated
The turbo bearings on my truck are lubed with engine oil, I can't say that I've ever had that portion of my engine apart before, so I guess it would depend on where the oil is coming from on the turbo. I have seen turbochargers leak oil before, but there were bad seals or loose fittings involved.
