Oil Pressure Seams LOW
Old Jan 20, 2004 | 06:57 AM
04RAM2500's Avatar
Question Oil Pressure Seams LOW
What oil pressure are you guys seeing?? Started mine this morning after around 15F degrees all night and it was just above 40psi. It hoovers around 40 psi when running down the highway which seems alright. But after the engine warms up to 220F and the truckis idling the oil pressure is around the low mark. It never goes below the red line just a little above it. The truck only has 800 miles on it.
On my old Durasmack it would run 80+psi on cold morning start up even with Amsoil in it and 40,000 mile then would hoover around 40 psi any other time.
Pressure just seems low on the cummins at cold start???
Thanks
Old Jan 20, 2004 | 07:02 AM
bulabula's Avatar
Normal. Mine is the same way. Keep driving it; this isn't a Duramax....
Rumor also has it that the oil pressure guage is nothing more than an idiot guage driven by the ECM and not really from the sender - but I can't verify it.
Old Jan 20, 2004 | 07:53 AM
mymaur's Avatar
Normal.
Old Jan 20, 2004 | 08:01 AM
CaptainMal's Avatar
o4ram2500,
All of us that got out from under a Duramax noticed that oil pressure thing right away. Join the crowd.
As mymaur said......"NORMAL".
Enjoy your Cummins.
Old Jan 20, 2004 | 10:16 AM
04RAM2500's Avatar
Smile
Thanks guys this makes me feel a lot better.
Old Jan 20, 2004 | 09:06 PM
y-knot's Avatar
I wouldn't worry to much about what your factory gauge has, it isn't really doing anything except sitting there looking pretty. Al Dodges are set-up to be dummy gauges, they read nothing and report nothing.
Old Jan 20, 2004 | 10:11 PM
PHX_ATC's Avatar
Normal. I freaked when I first saw it too.
Thanks to the fellas, I'm chillin now.
wvopowered
Apr 12, 2010 11:29 PM
RockysInMyBlood
23
Feb 13, 2010 11:26 AM
tool
Jun 3, 2008 09:31 PM
mullishacrew
May 15, 2008 10:28 AM
Power Ram 250 C
Feb 20, 2007 11:08 AM
