Oil fill cap....How to remove a broken cap?
Old Dec 29, 2007 | 05:22 PM
VFDFireman's Avatar
Any one have the fortune to break their oil cap?
I recently changed the oil, and I put the cap back on like normal and gave it two clicks like always.
Now the stupid thing will not come off... the cap just spins around the base. Apparently the spring mechanism has stripped or broke internally.
Any ideas? I was thinking that a bunch of string wrapped around the base and cap may be enough to get it off, but I haven't tried it yet. If I get it off with out mutilating it too bad, I think that I will just glue the thing solid.
Any tips would be appreciated.
Thanks.
Old Dec 29, 2007 | 05:34 PM
06 DIESEL's Avatar
The whole cover will come off and you can then work at it on your workbench without having to worry about getting pieces in the motor.
Old Dec 29, 2007 | 11:09 PM
D-Roc's Avatar
Unfortunately there is probably not a lot of options other than taking the cover off like the previous member mentioned. That sucks, good luck.
Old Dec 30, 2007 | 06:56 AM
BAD GRAVY's Avatar
you can lift the top part off your fingers,then use a pair of chanel lock pliers to spin the rest of it off.hope this helps..
Old Dec 30, 2007 | 07:03 AM
ptm600's Avatar
Just put a pair of slip joint pliers (channel locks) around it and squeeze it hard between them and turn. It should come off. I've never had this happen on my truck, but had it happen on my wifes jeep. Hope that works for you.
Old Dec 30, 2007 | 09:57 AM
Oilguy's Avatar
Ditto...
Jeeps are the worst!
Oilguy
Old Dec 30, 2007 | 10:20 AM
gsbrockman's Avatar
Originally Posted by Oilguy
Ditto...
Oilguy
I respectfully disagree.....Neons are the worst !
Old Dec 30, 2007 | 10:50 AM
DREDnot's Avatar
Happened to my jeep , too.
I ripped the top cap off with pliers and was able to now grab the plug portion and get it out.
The aftermarket replacment cap gave no problems.
Old Dec 30, 2007 | 08:14 PM
chwhit's Avatar
HAHAHA, this is hilarious, I've had it break twice on my jeep TJ! Both times I just ripped the top part of the cap off then used channel locks like said above to spin the rest right out. The funniest part about my exeriences is that both times I already drained the oil out so I had to wait for a buddy to take me to get a cap, moral to this story.......take the cap off before you drain the oil, I do it every time now no matter what it is.
Old Dec 31, 2007 | 10:32 AM
D-Roc's Avatar
Just be careful not to damage your valve cover
Old Dec 31, 2007 | 10:59 AM
MikeyB's Avatar
May or may not be related but keep the oil cap o-ring lubed with silcone grease. Will keep it from sticking to the valve cover.
MikeyB
Old Dec 31, 2007 | 05:55 PM
Oilguy's Avatar
MikeyB
Nah... The cap is just a POS... The inner ratchet action is plastic and it can't take any pressure without stripping...
Anyone want the real fix.. Fill it with silicone and put it back together....
3 years on the wifey's Cherokee and still no problem! lol
Oilguy
Old Jan 5, 2008 | 06:47 PM
VFDFireman's Avatar
Well I got the cap off with out damaging it. The internal ratchet legs had snapped off.
I got the cap and plug off clean enough that I will super glue them back together and keep it as a spare.
BTW, a new mopar cap cost me $12.
jsusany
28
Aug 28, 2017 03:45 PM
chw
Feb 14, 2009 07:12 PM
louddodge
Aug 28, 2008 09:28 PM
ajg617
Mar 6, 2007 02:22 PM
Iron City
Jun 12, 2006 02:37 PM
