Oh gurus of the 3rd Gens
Gentlmen (and Ladies)
Had a call from my bro on his 04 2500. Stopped just quit on him on the Hwy
on his way home from work.... code p0268? Any Ideas... Bone stock with less than 60k
Any help or ideas a much appreciated.
MM
on his way home from work.... code p0268? Any Ideas... Bone stock with less than 60kAny help or ideas a much appreciated.
MM
Just a little more info... he stated that if he lets it sit and cool off it will start and run for a little while....has an apptment at the dealer on Monday to get it looked at.
Thanks again guys.
MM
Thanks again guys.
MM
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Ahhh.....the dreaded stock lift pump. A common failure on our 3rd gens. I suggest he upgrade it to a Walbro or FASS set up. But it should be covered by warranty if he insists on the dealer repairing it. They will install the "in tank" version as a replacement.
Here is a better alternative, imo. http://www.glacierdieselpower.com/
Guest
Posts: n/a
From my understanding the pressure doesn't drop until the last second when the pump goes. There may be a few instances when there's a warning but I haven't heard of any, not saying it hasn't happened just none that I'm aware of. Anyone heard anything????
It's definately the lift pump. Best thing to do is get a Walbro kit. 391 for stock or lightly bombed, 392 if you are planning on sled pulling or drag racing. This is the right fix.
Wetspirit
Wetspirit
Thank you for the replys... he has Finally joined here, (MrHyde) After much poking and prodding...
I just wanted to give him some sort of resource that can help him along. After all he helped me find my 98 for $4000.
Maybe he will join in the search for more power... HE HE EH
