no wate to start light when pluged in
Old Feb 3, 2007 | 02:52 PM
rustyshakelford's Avatar
Originally Posted by 3500CTD
Block heaters suck alot of electricity dont they? Seems like a waste to plug the truck in when it's 40 outside just so warm air blows out of the vents. I only plug mine in when it gets below 10*(right now it is -4*). Can't wait for summer!!
well i dont have to pay anything when im at work so its ok. shes lucky to get plugged in at the house becuase i have to drag an extension cord all over gods greens earth
brett
Old Feb 3, 2007 | 07:05 PM
ford gone dodge's Avatar
I plug mine in and it still had to wait this morning for light to go out (3 deg.) and how long does it take for the motor to heat up this is the first deisel that I have had and it seems to take a really long time in the morning to heat up . but when it is warm it blows lots of heat.
Old Feb 3, 2007 | 11:36 PM
Timmer's Avatar
all dodge trucks and cars have great heaters. the prob is hte diesel's take a long time to heat up. drive it easy till you see the temp guage lift off the peg then drive it normal. dont use hight gear, let the motor turn a few RPM's to get it warm quicker.
Old Feb 4, 2007 | 12:43 AM
3500CTD's Avatar
Just got home and the temp is -18*. I started the truck around 4 this afternoon(-6*) and its been running since. Without plugging it in it started ok, but I sure wouldn't try it any colder. I've got it plugged in for the night now.
Old Feb 4, 2007 | 08:07 AM
dbossdiesel's Avatar
The ONLY reason I don't plug mine in unless I have to is because if you plug it in all the time you'll start to notice a three digit number on you electicle bill!
Old Feb 4, 2007 | 01:22 PM
Vinceg99's Avatar
Those things really suck that much electric eh?
Maybe ill plug it into the neighbors garage instead of mine theres is closer to where I park my truck anyways...lol
Old Feb 4, 2007 | 05:08 PM
duddin10's Avatar
I'm sorry that you are so cheap that your reason for not plugging in your truck at certain times is due to the electricity they use.
Old Feb 4, 2007 | 05:11 PM
duddin10's Avatar
My electric bill 3 digits anyway so I'm counting the kw on my meter from my truk being plugged in. I have more important things to worry about.
Old Feb 4, 2007 | 08:56 PM
3500CTD's Avatar
Cheap Im not cheap, but I'm certainly not wasteful. I just don't feel 40 is cold enough to plug a truck in. End of story. If you think 40 is an arctic blast, plug it in. If I was cheap I wouldn't be driving a cummins.
Old Feb 4, 2007 | 09:53 PM
belgianmagic's Avatar
Thats Normal
Originally Posted by Timmer
im up here in ohio and its starting to get cool at nights now. iv been pluging my truck in at nights, all night, but, even this morning when it was a shade over +15 deg. F , i got no wate to start light. i still let it set for a couple seconds while the grid heaters cycled, and it fired right up. no prob really, but all i was wondering is why? and does yours do that if you plug it in? its goin got get cold here tonight, +10 deg. F in the morning, ill see if i get the wate to start light then.
If the motor is already warm ,why would you need the heater...
Old Feb 4, 2007 | 10:04 PM
Timmer's Avatar
WOW i love the cold. but are you trying to say +15 deg F. is warm? JUST WHERE ARE YOU FROM?????
Old Feb 5, 2007 | 04:10 PM
DBLR's Avatar
You really don't need to plug it in untill -25 or less really. I left mine unpluged at -17 and it fired right up went right to high idle and I waited 15 to 20 min and off I went!
What a waste of fuel to have it sit running for 15-20 minutes. If you had a winter front then you only need to wait 2-3 minutes then drive as you will have 65 degree or warmer heat in 2 miles when the outside temp is above zero. Last night when it was -15 below zero ( with wind chill it was about -30) with all the flaps closed I let it set 3-4 minutes at 1000 RPM and drove home about 3 miles and I had 85 degree heat before I ever got home and I was driving between 25 and 55 mph.
Old Feb 5, 2007 | 05:35 PM
Timmer's Avatar
HA, will with the temps as low as thay have been, iv been getting the wate to start light now let me tell yea :P
Old Feb 5, 2007 | 09:00 PM
pevaguy's Avatar
One neat feature on the 06 with the Jake Brake is being able to start it, turn the jake on and engage cruise control. In no time at all the engine is at 180` with the cab toasty warm.
Old Feb 5, 2007 | 09:18 PM
Cool
NO , I was saying ...if you have it plugged in the motor is warm enough to not need the pre heaters... HOWEVER today mine was plugged in and @ 0* with a 25mph wind ,the pre heaters cycled
