New leak.....could use some help
Sorry for my lack of knowledge here...I read a lot more than I post. Engine coolant leak coming from small radiator looking device next to transmission on driver side.....had been losing fluid for some time but couldn't find leak (must have been small) now it seems to have sprung a good leak. Any ideas??
This came in the middle of my decision making process about my HVAC issuses with mode,blend and recirc doors...... guess the leak gets the attention first.
Thanks for your thoughts!
Thank you....Yes automatic, not yet got to work and it was leaking (still dark) have looked again but can't tell much until I get her home. There appears to be an accumulation on the box itself but it could be from one of the lines. I'll be honest....I don't know what this heat exchanger is or what it does...looking at diagrams wholesalemopar has it listed as a 'cooler torque convertor'.....somone had another post about a 'heat exchanger' today and a possibillity of bypassing it??
It exchanges heat between the trans and engine coolant system. It works both ways, both to warm the trans fluid (initially, to get the ATF up to temp - primarily needed with low ambient temps) and to remove heat from the trans fluid when hot.
You can remove it, but I wouldn't recommend it on a daily driver.
I think you need to determine exactly where the leak is. Make sure you don't have coolant in the trans fluid, or vice versa. That is a sure way to kill the tranny.
Well...got home and got everything apart to find a split connection hose. Thanks for the help! At the very least I learned what a heat exchanger is.....didn't even know I had one....
Smokkin
Jul 21, 2009 02:10 AM
dog rocket
16
Nov 15, 2007 06:01 PM
iddiesel
Oct 7, 2007 11:48 PM
tritont
146
Aug 13, 2007 03:54 PM
