new issues
Old Aug 9, 2013 | 03:50 PM
regert's Avatar
new issues
Ok here we go, so I bought a 2006 cummins and was told doesn't run as couple rockers are broken, I've repaired the rockers and wont start. It seems to not have any fuel to motor, I've searched and think there is a sensor on the back of the injection pump that cuts the lift pump is this correct?
Old Aug 10, 2013 | 06:44 PM
regert's Avatar
so after more inspection I've found that fuel makes it to injection pump but doesn't come out of the pump. anyone have any ideas if I'm into a injection pump or is there a issue with these that I could repair?
Old Aug 12, 2013 | 11:34 AM
regert's Avatar
Can someone tell me if a 2004 and 2006 injection pumps are the same? I can get a 2004 pump to try.
Old Aug 13, 2013 | 10:25 AM
gcssr's Avatar
I have no idea if they are interchangeable check p/n, call a cummins parts for info ;; sorry Grant
Old Aug 13, 2013 | 10:31 AM
gcssr's Avatar
If you have fuel at pump, you should have flow thru pump as the lift pump will self prime system, it requires no bleeding. Try disconnecting one injector line to see if system flows, if not remove line out of pump since you know you have flow in.
Old Aug 16, 2013 | 01:45 PM
regert's Avatar
I tried to opening the injector line and nothing so I opened feed line to fuel rail and still nothing so I opened line at pump and still nothing coming out. load of pressure off line that comes from the tank to feed the injection pump
dog rocket
16
Nov 15, 2007 06:01 PM
firesine
Aug 15, 2007 09:50 AM
bglz42
14
Nov 27, 2006 09:09 AM
Dr. Evil
Sep 6, 2006 11:43 PM
JJHACK
Nov 10, 2004 12:51 PM
