new code and couldnt find description in tech facts
Old Feb 28, 2006 | 01:06 AM
powerstrokin03's Avatar
Computer showed code p2679. What is that? Can't find its description anywhere. Thanks guys.
Old Feb 28, 2006 | 07:28 AM
RamWheelsBy4's Avatar
This what the online database I use shows:
P2679 Generic Coolant Degassing Valve Control Circuit Low
Old Feb 28, 2006 | 08:53 AM
Artie04's Avatar
Here is what 04 PowerTrain Diag manual said:
Symptom:
P2769-TRANSMISSION TCC CONTROL CIRCUIT LOW
When Monitored and Set Condition:
When Monitored: Continuously with the ignition on.
Set Condition: This DTC will set if the voltage detected by the ECM for the Torque
Converter Clutch Solenoid Control circuit is different than the expected voltage. Note: To
clear this DTC it is necessary to drive the vehicle at a sustained speed which would allow
the TCC and/or Overdrive Clutch to operate
POSSIBLE CAUSES
TRANSMISSION CONTROL RELAY DTCS PRESENT
GENERATOR SOURCE CIRCUIT OPEN
TRANSMISSION CONTROL RELAY OUTPUT CIRCUIT OPEN
TRANSMISSION CONTROL RELAY OUTPUT CIRCUIT SHORT TO GROUND
TCC SOLENOID CONTROL CIRCUIT SHORT TO GROUND
TCC SOLENOID CONTROL CIRCUIT SHORT TO OTHER CIRCUITS
TRANSMISSION CONTROL RELAY - POOR CONTACTS
TORQUE CONVERTER CLUTCH SOLENOID
ENGINE CONTROL MODULE
INTERMITTENT WIRING AND CONNECTORS
Old Feb 28, 2006 | 11:49 AM
Alright thanks guys, I guess it showed up because of the manual TC lcokup switch I have installed. Thanks
Old Feb 28, 2006 | 01:43 PM
JCROMAN's Avatar
put a 33ohm resistor inline with the ground wire and it will not set codes.....
Old Feb 28, 2006 | 02:00 PM
Nuttymopar's Avatar
I agree. I did do the relay wire tapping without the 33 ohm resistor and upon bogging the truck down to a crawl with the TC switch, turned on, I also got a P2769 code.
I then put the relay back to normal (no tapping) and placed a 33 ohm resistor inline from the switch to ground and have not gotten a code yet. I even I kill the motor one time sitting still in drive and hit the switch. So no codes as of yet.
JFortner5
Nov 28, 2006 06:36 PM
