New batteries installation procedure
Old Sep 2, 2010 | 07:10 PM
unbob's Avatar
Maybe this is a stupid question, but here goes ...
I'm planning to purchase 2 new Kirkland Signature #12866 batteries at Costco. Costco does not install - so I must.
Normally, I would simply disconnect each battery, remove each battery and then install/connect the new batteries. Simple enough.
But I vaguely recall reading somewhere that the battery install should be done some way such that power is never lost to the electrical system ???
Is this true? If so, what is the correct procedure?
Thx, Rob
Old Sep 2, 2010 | 07:13 PM
Rob's Red Ram's Avatar
just disconnect them and hook up the new ones .computer may reset no biggie will relearn shifting etc in a day or 2.
Old Sep 2, 2010 | 07:15 PM
madhat's Avatar
Administrator/Jarhead
I've never seen anything like that, I've changed my batteries out with no problems taking them both out. I looked in the dealer pub, did not see any special instructions.
Old Sep 2, 2010 | 07:20 PM
unbob's Avatar
Thanks guys! Glad to hear - let's keep it simple!
Old Sep 3, 2010 | 09:28 AM
Rednax's Avatar
It's always a good idea to clean, inspect, replace battery accessory items: cables, ties, fasteners, blankets, mounts, etc.
Think of the entire system you are addressing: The primary charging system.
Most guys get caught up in replacing component-by-component, and it's a strategy failure (especially on items like the cooling system). Go through it all, make it like new where it needs it, but the COMPLETE inspection is gold. (I'd at least remove all batt cable terminations, clean/grease, etc.)
Old Sep 3, 2010 | 02:16 PM
15 Digger's Avatar
To save memory for radio and such I read that you can wire a 9 to 12 volt small battery to an accessory plug and plug it in before disconnecting batteries.
Old Sep 3, 2010 | 08:39 PM
kokalit's Avatar
The batteries are wired in parallel. If you replace them one at a time, you won't lose radio and clock settings, or seat position settings or anything like that. If you take both of them out first, and THEN put the new batteries in, you will lose the clock and radio setting, etc.
Old Sep 4, 2010 | 11:45 AM
15 Digger's Avatar
Right, forgot 2 batteries, was thinking car.
Old Sep 5, 2010 | 12:50 AM
DaveB.inVa's Avatar
I was surprised the other day when I installed a GDP intake air horn on my truck. I wrote down all of my radio presets and everything before disconnecting both batteries before the install.
When I got back in my presets were still there and I had the batteries disconnected for at least 6 hours.
Old Sep 5, 2010 | 12:09 PM
pdogg's Avatar
^^^ same here... didn't lose radio presets, but did lose speaker settings (bass/treble) etc..
Old Sep 5, 2010 | 02:37 PM
shep1's Avatar
If you remove one at a time remember the loose Positive cable will still be hot.
ABDTR #5
Dec 16, 2007 08:31 PM
TxDiesel007
Apr 4, 2006 01:17 PM
supr
Jan 12, 2005 04:59 AM
Lary Ellis (Top)
Apr 15, 2003 06:29 AM
Lary Ellis (Top)
14
Nov 15, 2002 11:00 AM
