Need quick advice.555 or 600??
I visited my dealer today and test drove a 600,but they also have a new 555 and I heard the 555 is better on fuel is this true??
I may be getting one of these trucks if the price is right.
I can get the 555 for 34,117 out the door,it is a SL model,has AC tilt and cruise and a rubber floor which I like.And it is 4x4..
Quick replies needed
Thank you
Thank you
555 or 600
I'd get the 555 if I were you. Had 'em both. Sorry I made the move to the 600. Too many problems not worked out yet. It may yet turn out to be ok but a lot of trips to the dealer.
From: Eagle, Idaho. Please set your watch back 20 years when entering.
I believe there were some minor changes in the 600 tranny. It definitly has a different ECM. Knowing what I know now, (which isn't everything), I'd go with the 555.
100 Proof
100 Proof
Re: 555 or 600
Get the 555...........check the turbo diesel register forum also...there are more unhappy 600 owners there. I find it hard to believe there could be such a big difference in mileage between 2 600's. I would do a dearch for 555 vs 600 and see what the owners are saying what they would do next time. I made a huge mistake getting a 600 but didn't even know it.
Get whatever truck suits your needs/money the best. I wouldn't be worried which version of the engine it has. You're buying it for the Cummins engine which has already been proven. My 600 has almost 5000 miles on it and it's doing great.
I got him down to 32,117 for the 555,4x4 Quadcab,4:10 snow plow package anti slip rearend,towing group,but it is a ST model,rubber floor which I like,has air tilt cruise.
Does this sound like a good deal??
The newer autos might be able to take an exhaust brake. There is a good thread on the TDR about this. Carlton Bale is a Cummins engineer and has been keeping people up to date. There were changes, the question is if they are enough.
Take whatever invoice is, subtract 2%, take off the rebates, that's what you should pay. There is a dealer in St Louis who sells for 2% off invoice plus any incentives. You can calc your invoice price at www.kbb.com or www.costcoauto.com
Originally posted by Dave65
Does anyone know what type of injector pump is on the 555?
Is it the VP44,I hope not..Thanks
I know very little about the 555 system and even less about the 2nd gen
but as understand it, the 3rd gen does not have an "injection" pump. They have three pumps: (1.) low pressure (~20psi) lift, (2.) medium pressure (~180 psi) pump and (3.) a high pressure (~23,000 psi) pump. The hig pressure fuel is routed to a single fuel manifold (common rail) that continualy provides high pressure fuel to all six injectors. The injectors are electrically opened and closed to supply the high pressure fuel to the cylinders. The black boxes fool the ECM into varying the actual pressure in the High Pressure Common Rail and/or vary the timing of the electrical signals to the injectors.Hope that helps.
The Boss Hog
(Still learnin' . . . . . .
Get the 555.... No third injection for emissions and no CAT!
You should be able to get minimum... invoice price minus $2500 rebate
I also got a free bedliner and a fre tonneau cover.
Tell them the 555 is going to be sitting on the lot for a long time cause everybody wants the 600. Get that price down!!!!!
Thanks guys that does help,I have two dealers working deals,one is hell bent on a lease,and I dont need a lease,but that one also will through in a bed liner,a tonoue cover would be nice too
I don't plan on bombing right away,besides I dont think my VA BOX and DD1 injectors will work in the new trucks,not sure though.
