Need help with vibration!
Old Feb 26, 2008 | 04:33 PM
Sniper05's Avatar
Alright guys i have a vibration when i am rolling to a stop light or at low speeds and not giving it ant throttle, if i'm going through the gears or on the interstate then its nor there but when i go to come to a stop or just basicly not giving it fuel and letting it cruise say around 10mph then it is very noticeable! I thought it might be my clutch at first cause the throw out bearing is starting to squeal, but if it was the clutch wouldn't it vibrate somewhat all the time, i then thought it must be a u-joint but i climbed under the and everything seems to be tight except maybe the back one were it almost looks like the caps have moved alittle bit? Please help me, its driving me nuts Thanks guys!
Chad
Old Feb 26, 2008 | 04:36 PM
billie's Avatar
Check in neutral for u-joints, it unloads the drive system. The rear one is probably shot.
Cya
Old Feb 26, 2008 | 05:00 PM
Sniper05's Avatar
will do thanks man!
chad
Old Feb 26, 2008 | 09:25 PM
TreeFarm's Avatar
G56? There is a TSB out regarding vibration at idle only due to a bad dual mass flywheel. Some have been fixed under warranty.
http://dodgeram.info/tsb/2005/18-015-05.htm
Old Feb 27, 2008 | 07:14 PM
Sniper05's Avatar
Well i think i fixed it guys! I took the drive shaft out today, and sure enough the rear joint was toast! I had bought 2 u-joints planning on changing them both but didn't have enough time so i just did the rear for now! I drove down the road and no shake or vibration! Thanks for all the help guys!
Chad
Dave04600
18
Aug 7, 2012 10:12 PM
6BT12V
Aug 15, 2008 08:05 AM
MARKY MARK
Feb 1, 2007 10:46 AM
dodgedsl03
Jan 18, 2007 10:08 PM
kyle@ftlb
Feb 27, 2004 10:24 PM
