Low Power, Boost when Cold
Hello all. Long time member, not a super poster. Have a problem I’m hoping you can provide some assistance with, or have experienced yourself.
I have a 2005 Dodge ram 2500 with the Cummins (specs in the sig), 60,000 miles. I’ve had no issues with this truck over the 17 years I’ve owned it, impeccable service record and everything replaced with OEM or higher quality parts. Truck has run flawless, and last trip out was removing the boat (10,000 lbs) and it did fine, pulled fine, built boost fine, etc. I went to use it the other day, and it’s a dog (it has been very cold up here in New England). Step on the gas and it’s like driving a non turbo truck, very slow to accelerate, and very slow to build boost. Once warm (driving for 20-30 min) if I punch it, I can build to 20psi (and it stops dead at 20psi), but still does not pull hard (like it used to). It does not feel like the truck it was, and assuming it’s not getting the fuel it needs.
I appreciate any help you can provide, or at least items that you have noticed that are those “stupid silly” items that cause big headaches. |
Originally Posted by TAS05CTD610
(Post 3379573)
I appreciate any help you can provide, or at least items that you have noticed that are those “stupid silly” items that cause big headaches. Good luck, back to morning brew . . . [coffee] |
Thanks FMB, I did check it over to see if I had any cracks, but would not be able to see any leaks for obvious reasons (again it was strange how it just happened so fast). (almost like it failed just sitting in the drive way), and the way I can hit 20 psi really fast, then it's like hitting a wall. I'll have to pull it throw some test plugs in and pressurize it, I limit boost to 35 psi currently so I guess that's what I'll test too. but as of each time I've driven it, 20 psi on the money (and not like 18) but 20 on the dot (others have said teh electronic boost controller).
Thanks again for the input, I'll throw it on my list of things to check. |
(Post 3379688)
| All times are GMT -5. The time now is 07:11 AM. |
