Long cranking
Old May 2, 2014 | 09:10 AM
outdoors's Avatar
Long cranking
Just a question for you guys and gals.
About a month ago I did a trip down the highway
And since then my truck cranks awhile before it will start.
I changed the fuel filter about two weeks ago
I put in a AFE high flow 3micron filter. I've been using those since I bought it two years ago. For about four days after the new filter the truck started great!! Once it's running it runs great!! No smoke no noises nothing. I'm just wondering if someone has any?? It's a '06 CTD. All stock except intake and exhaust. Oh and I did clean air filter about two weeks ago also. Thanks in advance for any ideas!!
Old May 2, 2014 | 11:00 AM
soulezoo's Avatar
DTR 1st Sergeant
Hi, this question has been discussed a lot of late. I invite you to use the search function and find some of those threads in both this section and the 3rd gen high performance section.
The short answer is worn injectors (excessive leakback) or pump or a slight leak somewhere.
Old May 2, 2014 | 11:08 AM
outdoors's Avatar
Shoot! That's what I was afraid of! Thanks.
Old May 2, 2014 | 03:39 PM
Dr.Dizzle's Avatar
Just so you are aware, The AFE D2 is not a fuel/water separator as per AFE. Given that information, this filter being that it is a filter only, is not a viable option for the CTD's as it does not meet O/E specifications. You are likely looking at new injectors.
I currently use the Baldwin PF7977 which is the best you can currently purchase for the OE canister at 5um.
Old May 2, 2014 | 05:48 PM
outdoors's Avatar
Thanks for the great info DrDizzle!! Here I thought I was doing a good thing by using the AFE filter
Old May 9, 2014 | 11:56 AM
estaca's Avatar
HI guys just replaced the stock lift pump with napa lifetime limited
truck starts faster , and cleaned the crank position sensor I also
reset the steering gear box that was way out .these have the
locknut and screw at the the top . also looked at a new box .
the factory box on our is sagnaw aka delphi so we know not to buy another one as this only went 120 k and this truck has all hwy miles ! also using stanardine diesel treatment
Old May 9, 2014 | 12:06 PM
estaca's Avatar
I was also shocked at the price for injectors , stanardine fuel treatment is cheap compared to injectors rebuilt or new ,and the injector pump ! protecting that to is very important . as these are in the 2 k range mine starts in 3 to 4 sec i timed it .
turbo246
Nov 9, 2008 01:55 PM
CmminsBeast
19
Jul 7, 2008 12:07 PM
ScotS
Jun 5, 2008 03:04 AM
DL1221
Jul 14, 2006 08:43 AM
JAKE03CTD2500
Jun 14, 2005 12:47 AM
