Lift pump leak fixed
Old Jul 12, 2003 | 08:14 AM
MikeyB's Avatar
I removed the lift pump yesterday. The o-ring seal was damaged. Apparently the pump wasn't aligned properly and allowed the seal to get pinched. The pump centers itself via the outlet tube and o-ring.<br><br>MikeyB
Old Jul 12, 2003 | 08:32 AM
Mexstan's Avatar
Re:Lift pump leak fixed
Thanks for letting us know what you found. Too few users of this site let us know the solution to their problem(s).<br>Presume all you did was install a new O-ring and reinstall the pump?
Old Jul 12, 2003 | 11:35 AM
MikeyB's Avatar
That is correct. Just a new o-ring. About a ten minute job. One thing I didn't understand is the manual didn't mention lubing the o-ring. I went ahead and lube the o-ring with silicon grease. The kit contains just about every seal needed for the fuel system. Also included 4 new bolts with thread locker for the lift pump.<br><br>MikeyB
8Lug_hotrod
Apr 18, 2021 08:07 AM
Shake-N-Bake
Feb 20, 2012 04:29 AM
bgflatbed
May 10, 2010 10:01 AM
jrs_dodge_diesel
41
Aug 2, 2007 08:06 PM
jwtuc
14
Mar 22, 2004 08:35 PM
