Leveling truck
Old Mar 21, 2008 | 12:44 PM
sundance54's Avatar
Leveling truck
On my 04.5 4x4 3500 Dually I would like to level it. Instead of raising the front why not lower the rear? I looked at the springs on top of the rearend and there's two big spacers about 5/8 thick each between the springs and rearend. If these were taken out would there be any problems?
Old Mar 21, 2008 | 01:04 PM
bansh-eman's Avatar
seems like lowering the rear would be a bad choice if you plan on towing. you want it up so with the extra weight it will squat and not bottom out
Old Mar 21, 2008 | 07:51 PM
nelrod's Avatar
do a search, people have done it. Mine has spacers that could be put ontop, then use same u-bolts. I would recommend putting bilstein shocks with the 2 inch levelers, you will think you have a new truck it will ride so much better. I put the Bilstein leveling kit, (longer coils with more turns and the shocks, best money I have spent on truck.
Old Mar 21, 2008 | 08:05 PM
FishingFather's Avatar
I lowered mine in the back doing what was just said. To make it easier, spend the $20 or so and buy new u-bolts to start with as on the two trucks I have done this one at least one gives problems going back together. I tow (but not all the time) and have never had any problem at all, but I am not near the max capacity either.
Old Mar 23, 2008 | 07:39 PM
sundance54's Avatar
The truck already sets so high in the back that it's hard for me to see in the bed. The only thing we tow is a 28ft car trailer,so I don't think it well bother it much.The trailer loaded weighs in at 7,000lbs. If I would raise the front end what is best? A taller spring or 2in. spacer.
Gene007
17
Oct 22, 2007 04:46 PM
dodgintrouble
36
Oct 16, 2007 07:02 PM
Dusty004
Apr 4, 2007 11:22 PM
paul4romtexas
Jul 18, 2006 11:27 AM
Wes in TN
Aug 29, 2005 05:07 PM
