Kore Installed
Old Oct 17, 2009 | 02:30 PM
Mocho's Avatar
Originally Posted by Fisherguy
... and make sure you undo the sway bar end links...
I wouldn't unless your replacing them, because most of the time if you try to remove them they are finished. Your must better off IMO to unbolt it from the frame, and put a jackstand or something to support it a few inches down. I learned that the hard way on my old truck, had to buy new 2 end links.....
Old Oct 17, 2009 | 09:32 PM
Fisherguy's Avatar
Originally Posted by windowman
I had mine done over a year and a half and have been very happy with the rides except 315 still rub on buchwacker flares, but better that the dealer installing mud flaps 3 times and many holes in wheel wells
The new shocks made a big diff as well,I have not put blocks in back yet!
Very happy the way it looks right now,may go with air bags down the road?
1 sway bar link broke and Kore sent new right away, was very happy as the supplier I got from is not selling their stuff anymore
Has anyone replaced control arms and with what brand?
How much did those 285 75 set you back and how are they in the snow?
My other winters are shot and need some new ones, anybody try the new Dunlups yet?
I only used spacers but you're in the same boat as me, I had to trim my ATS flares cuz my tires were rubbing. I want to get ½" longer control arms, was looking at these ones from DTProFab. haven't heard anything bad about them and I'm anxious to get some mud flaps on.
Old Oct 17, 2009 | 09:51 PM
Danderson's Avatar
1/2" longer arms + 35"'s=no rub on mudflaps with stock wheels or H2's
Old Oct 17, 2009 | 11:17 PM
Mocho's Avatar
That is odd. I guess it depends on what type of mud flaps. With mine 6" lift and 35" tires, i had maybe 1/2" clearance. By the design of them I could tell they were really good at killing tire clearance though. With 3" and stock control arms they rubbed something horrid.
Old Oct 17, 2009 | 11:20 PM
Mocho's Avatar
Just go all out and get a full on suspension lift You won't regret it!
Old Oct 17, 2009 | 11:38 PM
Fisherguy's Avatar
6" lift vs. 2", big difference.
I'll pass on the full lift though, I'm happy with it as is, just gotta do control arms and a track bar.
Old Oct 19, 2009 | 04:26 PM
Thundercloud's Avatar
Originally Posted by CampingMan
I finished up my Kore HP install last wednesday, got an alignment and new Toyo AT 285-75 tires on Friday and went out camping on the weekend to test it all out. In short the ride is great on the highway, no more swaying and bottoming out. Offroad is very controlled and harshness isnt really that different from stock. Tire grip is great and noise is non existant. I am sure most people would have went 35" but I didnt want to lose much power and cause more front end wear. The 34" tire is a good comprimise I think.
In front I only gained about 2 1/8" while the rear maybe an 1". Install was fairly straightforward with rusted nuts being the only pain. All the parts looked to be of decent quality.
With the boat on top of the truck I hooked up my 7500lb trailer and noticed the rear didnt squat much more than stock. Maybe air bags wont be need as soon as I thought! With the lift installed it is not as level towing when it was stock though.
I still need to adjust the headlights and speedo. Suspension wise though, I think this truck is dialed in. My truck is no desert chase truck and should suit the logging roads I drive nicely. Axle shift F to B and L to R is hardly noticible so I doubt I will do anything in the near future to correct it. The guy at the alignment shop did recommend a steering stabilizer if I was going to get something.
For the price I dont think it can be beat!
I set up my truck just like yours 2 years ago except using Carli/Thuren products. I set up my rear spring pack just as you did. For what I need the truck for it works good that way. I also have the same tires, size, etc. and you are right they are a good compromise to the 35".
Old Oct 20, 2009 | 03:59 PM
RiverRat2's Avatar
If you do the track bar be sure to check the track bar bushings while there...
if they look even slightly worn,,,,,, change them
silverrhino
20
Oct 22, 2007 11:01 PM
trik396
Aug 9, 2006 10:45 AM
Viperdew
Jul 21, 2006 07:02 PM
02growler
Jul 12, 2006 09:57 AM
EricK
Apr 15, 2005 04:34 PM
