Key off battery draw.. again?
Old Jul 20, 2009 | 07:01 PM
HudsonValleyRam's Avatar
Thank you for the responses on my thread yesterday.. No fix yet. I have since pulled ALL the fuses out of the fusebox (at the same time) and still have a 4.86 amp draw thru the hot leg feeding the underhood fusebox. This leg must feed another circuit not protected by a fuse in this panel. I have also checked the grid heater relay, it is not closed. Does anyone have any idea what will draw this kind of amperage continuously?
Old Jul 20, 2009 | 07:34 PM
carl48's Avatar
remove the lead going to the alternator, there is six diodes in it if one of them is leaky it will cause the symptoms you have
Old Jul 20, 2009 | 07:41 PM
carl48's Avatar
get a key chain compass, hold it on the wiring harnesses the one the needle lines up with is the culprit next open up the harness and check individual wires
Old Jul 20, 2009 | 07:42 PM
I did disconnect alt. lead.. Still had draw. Thanks. I think altenator lead is fed directly from pass. side batt. thru fusible link. My draw is from drivers side batt. in lead to fuse box, leading me to believe draw was in a circuit fused in this panel, but pulling all the fuses kind of disputes this theory. I am at a loss.
Old Jul 20, 2009 | 07:44 PM
Which harness are you speaking of with the compass trick?
Old Jul 21, 2009 | 03:25 PM
booman70's Avatar
Are your batteries dying on you when left for a period of time. How long?
Old Jul 21, 2009 | 09:29 PM
carl48's Avatar
hold the compass over each wire or harness on the fuse box. the compass will line up with two of them the red one that you have the disconnect on and the one the draw is on. follow the draw one to see what it feeds
Old Jul 23, 2009 | 06:17 AM
24-36 hours batteries will be stone dead.
Old Jul 23, 2009 | 06:58 AM
GEN_X's Avatar
i dont if i responded to your other thread or not but i had this problem as well and my grid heater fouled up and would stay on even when the truck was off. the batteries would nearly be dead over night. Just a thought
Old Jul 23, 2009 | 08:31 AM
I looked into grid heaters. They are fed from pass. side battery thru a fusible link and relay. (And the relay is open). My draw is on the lead from the drivers battery feeding the fusebox. Thanks anyway.
Old Jul 23, 2009 | 11:26 AM
homewrecker's Avatar
How about the starter?I had one on my 98 12V draw the batteries down.Chased my tail for a month.I guess the solenoid was leaking,I really don't know.Swapped it out and the problem went away
Old Jul 23, 2009 | 12:20 PM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
What kind of meter are you using? Clamp on or inline?
Old Jul 28, 2009 | 08:37 AM
Using Inline Ameter For All Readings- I Finally Gave Up- Truck Is At Dealer (under Warranty I Hope)- I Will Post When They Figure It Out.
Old Nov 19, 2009 | 01:54 PM
jfdid's Avatar
Any word on this?
cLAYH
Apr 24, 2015 10:29 PM
AggieJustin
Feb 10, 2010 06:26 PM
HudsonValleyRam
Jul 20, 2009 08:11 PM
1993rollincoal
Mar 2, 2008 11:08 PM
stix
Aug 23, 2007 09:39 PM
