Jobber or Mopar for oil pressure sender?
Old Jan 16, 2011 | 06:18 PM
ratsun's Avatar
Last night on my way to work, dash chime would go off and oil pressure gauge would drop to 0 every time I let the engine idle so I hook up a mechanical gauge and of course I have 20 psi at idle.
So today I decide to pull the wire harness off the sender and see if maybe the connection is bad.......... seems its a little more than just the connection as oil starts dripping out of the sender LOL
Anyway has anyone had luck with an aftermarket jobber sender or is this one of those dealer only type parts?
Old Jan 16, 2011 | 08:27 PM
firestorm's Avatar
On my 01, the sender was $68 at Cummins, verses $150 from Dodge. The 'sensor' detects pressure or not. The PCM, calculates what the pressure 'should' be, and that is what is shown on the dash. That is why I added a mechanical oil psi gauge in the A-pillar. I just got the 03, so I am not sure about it, but will be re-installing my gauges.
Old Jan 16, 2011 | 09:02 PM
ratsun's Avatar
I will check out my local cummins.
I know its a simple yes or no type sender but some times jobber stuff is really not up to par (not that the OEM one was very good IMO ) and sometimes not really all that far off the OEM stuff for much less money.
Old Jan 17, 2011 | 03:23 PM
firestorm's Avatar
The sad part is, when you buy it from Dodge, it comes in a 'Cummins' box, with a Chrysler label on it. I may be wrong, but I think the part number is even the same.
Royal
17
Jan 24, 2006 04:43 PM
wcbcruzer
May 18, 2005 03:26 PM
turboram
Feb 18, 2005 10:33 AM
