ISB or ISX
Old Dec 14, 2006 | 06:35 PM
TurboTed's Avatar
ISB or ISX
What do these mean? What is the 5.9 ?
Old Dec 14, 2006 | 06:47 PM
dodgepower88's Avatar
The "ISX" is the 15 liter cummins highway engine with DOHC. I know that the older 5.9's were called "ISB"s, but I am not sure if the newer ones are still called that. Hope this helps a little.
Old Dec 14, 2006 | 07:27 PM
TopBanana's Avatar
The ISB is the 5.9L. ISB stands for interact system, b-series. all 98.5 and up 24 valves including common rails are isb's. also, the 3.9L 4 cylinders are considered ISB's.
12 valves are 6bt's, and older 3.9L's are 4bt's
ISX is a 15L x-series engine in heavy trucks.
i'm pretty sure that "IS" means it's computer controlled, if that's an easier way to think about it.
Old Dec 14, 2006 | 09:27 PM
TurboTed's Avatar
Thanks!
Old Dec 14, 2006 | 09:37 PM
TurboTed's Avatar
Here's some more info I just found(if anyone else cares!)- What Is This Interact System? It's a new engine design platform that combines sophisticated electronic engine controls with high-pressure fuel injection and high-strength componentry for an engine that outperforms every competitive diesel on the market today.
Describe The ISB In 15 Words Or Less. The ISB is a fully electronic, 4-valves per cylinder, in-line 4 or 6-cylinder turbocharged diesel.
Old Dec 15, 2006 | 02:16 AM
Smkn600CTD's Avatar
The Common Rails are ISBe.
hovisimo
Dec 1, 2007 01:26 PM
hovisimo
Nov 30, 2007 10:17 AM
dieselfuelonly
Jan 26, 2007 11:11 PM
possum
May 24, 2005 11:30 AM
4x4
Apr 6, 2003 04:28 PM
