Intermittent low knocking sound
Old Jan 18, 2009 | 02:54 PM
mic646's Avatar
Before I take my truck back to the dealer to have them look at it I figured I would try to explain what my concern is and maybe someone might have an idea what it may be.
Truck only has 22k on it. At idle I get an intermittent low knocking sound.It will knock several times and stop for several seconds and then start again. It kind of sounds like a rod knock. I can’t hear it while I am in the cab, only when I am outside the truck. When I open the hood it sounds like it is coming from the right front area. I can hear it while I am driving like in a tunnel, with the window down, only on deceleration. Under load I don’t here the knock. No smoke and still plenty of power.
Another thing that I get but never paid too much attention too, is under load or coming up a hill if I floor it I get what I would describe pinging. Like a gas motor using low octane fuel. It’s not too bad mainly annoying. It will do the same from a stop for a few seconds if I munch it until the rpm’s get up.
This concerns me but maybe it’s normal for the 3rd gens. I know if I take it to the dealer without an idea what it may be they will just say it’s normal. The only reason I am going to the dealer is it is under warranty.
Thanks
Last edited by mic646; Jan 18, 2009 at 02:55 PM. Reason: Add information to question
Old Jan 18, 2009 | 05:02 PM
NickBeek's Avatar
Mine has an intermittent knock at very light throttle too, it is very unnerving. The pinging is "normal" for these things. Not sure on the knock, but I am at 87K miles and it has been doing it as long as I can remember.
Old Jan 26, 2009 | 06:06 PM
mic646's Avatar
Took the truck to the dealer. Mechanic listened to it and said that he has had a few like mine that made the same noise. He said he was able to correct it by re-setting the timing on the injection pump.
Picked it up later on and the intermittent loud rattling noise is gone.
smokester
May 27, 2011 05:31 PM
grizzlydiesel
Jan 12, 2005 12:03 PM
grizzlydiesel
Jan 11, 2005 03:56 PM
turbov6joe
Sep 2, 2004 10:44 AM
mitchkim
Aug 6, 2004 03:36 PM
