How to tell if the unit bearing is going bad?
Old Jan 17, 2010 | 05:41 AM
Mark Hodowanec's Avatar
Originally Posted by Matt S
I grabbed them but no movement. I tried using a pry bar and still no movement. Maybe they aren't bad enough to have that much play in such a short distance.
If there is no movement then I doubt that it is the u-joints.
Previously I said (edited since):
Also, I assume that you are talking about the axle u-joints, not the driveshaft u-joints. Your truck has locking hubs, so unless you have the hubs locked in, or, are in 4 wheel drive, the front axles should not be spinning. If they are not spinning and your getting the noise, it's definately not the u-joints.
Sounding more & more like the hub bearing. The hub bearing has two bearings in it - the wheel bearing bearing & the needle bearing that supports the half shaft. If the needle bearing is bad the half shaft flops around in the bearing and also spins a little even when hubs not locked or in 4x4. This definately causes a vibration. Mine went out at 190K miles.
I was thinking about my Excursion when I wrote the above. Ram's don't have locking hubs.
Old Jan 17, 2010 | 01:53 PM
Highway 4x4's Avatar
Who has locking hubs? I don't see it in the sig or profile.
Old Jan 17, 2010 | 02:22 PM
Brain Fart - I was thinking about my Excursion. I'll go back & edit the post...
Old Jan 17, 2010 | 10:08 PM
You put big tires on it, I bet it's a unit bearing. If it gets bad enough you'll need a tow truck so get it fixed while it still moves. Look for any signs of rust color coming from the u-joints. Sound changes with speed so probably not ball joints or stearing. If you don't find the problem, it will find you.
Old Jan 24, 2010 | 08:07 AM
Matt S's Avatar
Well it was the U-joints. The noise is gone. The drivers side was the worst of the two. The needle bearings had worn ridges into the U-joint. I didn't have a helper to try using the truck steering to press out the unit bearings so I used a 3-lb hammer and a socket extension. It took some time but and two shots to my thumb but the job is done.
Thanks for all the advice and suggestions!
Old Jan 24, 2010 | 08:14 AM
rocksteadyrobk's Avatar
http://www.youtube.com/watch?v=8zHBxwwOg6s
This is a great vid from Spider Trax on Unit Bearings
Old Jan 24, 2010 | 12:37 PM
bb45's Avatar
awsome vid just goes to show u get what you pay for
Old Feb 11, 2014 | 09:59 PM
mtb1982's Avatar
i know this an old thread but i have a question. i think that my wheel bearings are going south in my 03 2500 4x4. i did the wheel play test and had some play in them both, worse on the left side. also when turning slow like going around a corner or pulling into a driveway i can fell slight jerking like 4x4 is locked in but it's not. i have no bearing noise going down the road but an annoying squeaking at cruising speed; 40+ mph. its a manual shift t-case if that makes any difference. any help is always appreciated.
Old Feb 12, 2014 | 05:17 AM
Matt S's Avatar
Have you checked the universal joints?
DF5152
Nov 24, 2017 11:13 AM
GLHS
Apr 15, 2012 08:10 PM
jlipskoc
Dec 4, 2005 02:35 PM
