how to replace carrier bearing?
Old Nov 18, 2007 | 04:51 AM
bsj04's Avatar
my carrier bearing is wore out, its riped all the way around and has about 1/2 of play. where do i get a new one and how big of a PITA is it to put on?
Old Nov 18, 2007 | 05:01 AM
XLR8R's Avatar
You should be able to pick one up at NAPA, Scott... pretty simple to replace! Might think about installing a carrier bearing spacer to match your lift while you're under the truck.
Old Nov 18, 2007 | 06:08 AM
bsj04's Avatar
yeah i was planning on that and some u-joints while i got it apart
Old Nov 18, 2007 | 06:11 AM
XLR8R's Avatar
How thick of a spacer?
Old Nov 18, 2007 | 05:49 PM
bsj04's Avatar
havent measured yet but thinking about 1/2 to 3/4. ill see what it looks like and how it drives.
Old Nov 18, 2007 | 06:02 PM
bsj04's Avatar
so... has anyone every replaced or bought one?
Old Nov 18, 2007 | 06:11 PM
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
Remove rear propeller shaft.
Mark the two shafts (REFERENCE MARKS) for installation reference.
Remove slip joint boot clamp and separate the two shafts.
Use hammer and punch to tap slinger away from shaft to provide room for bearing splitter.
Position Bearing Splitter Tool 1130 between slinger and shaft.
CAUTION: Do not damage shaft spline during removal of center bearing.
Set shaft in press and press bearing off the shaft.
INSTALLATION
NOTE: Two types of center bearings are used and are not interchangeable. Install the same type as the vehicle was built with.
Install new slinger on shaft and drive into position with appropriate installer tool.
Install new center bearing on shaft with Bearing Installer Tool 6052. Drive on shaft with hammer until bearing is seated.
Clean shaft splines and apply a coat of multi-purpose grease.
Align master splines and slide front and rear half-shafts together. Reposition slip yoke boot and install new clamp.
Install propeller shaft in vehicle.
Old Nov 18, 2007 | 09:52 PM
bsj04's Avatar
thanks for the reply vzdude.
ajb1974
Mar 18, 2015 05:49 PM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
Stroke This 24V
Jul 3, 2003 02:40 AM
rich
0
Oct 4, 2002 06:18 PM
