How many miles are people getting on their 48RFE?
Old Jan 28, 2009 | 11:09 AM
FishingFather's Avatar
Almost 110k miles and no problems, and no servicing since I bought it. I suppose it's time to do some "routine" maintenance on it. Love my truck...
Old Jan 28, 2009 | 12:22 PM
kantdrive55's Avatar
DTR Advertiser
Servicing is going to play a major part in the life of a transmission. If you do change at every 30k even less if you are working them harder you can expect a longer life than if you don't service them. Also increasing the power will cut down on the life span. In a lot of cases simply upgrading the torque converter and valvebody will allow you to run some extra power and take care of that transmission for you.
Old Jan 28, 2009 | 07:17 PM
DCDOC's Avatar
48re
My 04 calif. version lost the TC at 44,000, which took out most of the transmission. I do run the EZ at #3 but i"m real easy with the go pedal. I also tow 12,000 6-8 times a year.THe tranny may be tough but these TC are way too sloppy!
Old Jan 28, 2009 | 08:23 PM
BEARHUNTER's Avatar
From: Well I thought I lived in America, but its looking more like france every day.
my tranmission went out at 24k with no programer or other mod for the engine. Got the transmission rebuilt all stock. I then bought the jr and have had no issues with the tranmission so far. I think it really all depends on driving habits and remember its a mechanical item! it will break down sometime, do your maint. and take care of it and it should hold out longer.
Old Jan 28, 2009 | 08:30 PM
Kenny D's Avatar
i smoked mine at 17k climbing a hill after my lift was on climed it stock and spun the hole way up in 4 hi put on my MT and they didnt spin but the truck came to a stop instead
changed the converter and valve body but she still went now i have a full built DTT from ricahrd in miami had a problem slipping in reverse and 3rd but he made it good so im prayin she hold for years i baby it adn rarly get on it
How many miles are you guys getting out of your full built trannys driving it like you care abou it ??
Old Jan 28, 2009 | 08:53 PM
RTA Cattle's Avatar
mine is still going at 146,000. Its getting pretty sloppy though.
Old Jan 29, 2009 | 01:30 PM
jasonstacked06's Avatar
ive always wanted a diesel. my dad retired from gm so I get a discount but ive always heard cummins was the best motor and dodges transmissons where bad ive always heard that ( not trying to start anything its just what ive heard) I figure if there transmissons are THAT bad they would fix it because its only costing them money in the long run under warrenty work . Ive heard you cant beat a allison but the duramax moter realllllllllllllllly sucks ive heard. so i bought the dodge. love the truck and hope and pray i dont have trouble. my mom has a jeep and has had the trans replaced a few times and the guy that replaced it acted like it wasnt a big deal its normal. Like it was stated it is habbits and maintance but also a few could go wrong and also I dont know if anyone thought about it but have you EVER seen how dealers drive??? no telling how it was treated before you picked it up lol I hate taking to get my oil changed because the maintance people are just as bad.
Old Jan 29, 2009 | 01:57 PM
BEARHUNTER's Avatar
You know I have friends that own chev's and Fords and they have had transmissions go out on them with stock power. For the most part I think that the big three make good transmissions but they are mechanical and will break down from time to time. My friend at work got a suncoast transmission, went out on him at under 1k crap happens. I dont think your going to get exact science by asking here on a forum how long the 48RE has lasted for people. There are to many variables to take into account but it does make a good discussion though. I would guess the biggest thing that contributes to tranmissions going out would be to much heat. I would like to get a trans. cooler and a temp gauge for it. I tow alot and I think that would help a lot.
Old Jan 29, 2009 | 02:02 PM
annabelle's Avatar
Got 220,000 miles out of mine before the rebuild.
Old Jan 29, 2009 | 03:03 PM
BEARHUNTER's Avatar
Thats impressive!! what was your maint. like every 30k?
Old Jan 29, 2009 | 06:31 PM
lillTIM's Avatar
Originally Posted by Beavermike
I have the 04, but only about 80,000 miles. At what point are people servicing, rebuilding, or whatever on this tranny?
Also, is it possible, or feasible to replace an 48 with a 68RFE tranny?
I have an 03 with an 48RE with around 150,000 on and the torque converter just went out. I did have to replace the transducer and pressure solenoid at 140,000. I bought the truck used with 111,000 and don't know how it was driven before.
Old Jan 29, 2009 | 07:02 PM
annabelle's Avatar
Bought the truck in 06 with 91,000 heavy towing miles. Put the rest on commuting at least 100 miles per day(mostly interstate at 1800 RPM). Truck was stock when I bought it. Was told tranny was shot when I rebuilt it. Was beginning to slip. Fluid and filter every 20,000 miles.
Old Jan 29, 2009 | 07:28 PM
shortie's Avatar
130,000 on mine dtt update kit, tcs 89h convertor, homebrew valve body.
48re planetaries are much stronger then the 47, the leakage areas and the convertor are the same.
Pull 8 t0 14 thousand 50% 0f the time, tst on 4x4 since 26,000 fulltime.
Address the leakage areas, put a tighter torque convertor in and they are **** near bulletproof barring total ignorance or over 450 hp.
Old Jan 29, 2009 | 09:09 PM
Spooler's Avatar
Guy just posted in the 3rd Gen performance section and he has 400,000 miles on the original 48re.... Take a look
