How do you check lift pump voltage?
Old Feb 23, 2010 | 05:03 AM
Dieselhed's Avatar
I've been having low fuel pressure issues for about 3-4 months now and finally it got so low the truck died. It will still start and run but pressure is really low (2-4 psi). I have a Walbro pump with 2 mic filtration set up. I've replaced the filters twice and the pump twice. Dropped the tank and inspected the pick up tube which looked fine. Thinking now the voltage to my pump may be failing. I replaced my stock batteries with Interstates about 2 years ago and ever since I've had to clean the terminals about every 2-3 months because of corrosion. They sweat a little as well. How do I check the voltage the pump is seeing and what do I need to do it?
Old Feb 24, 2010 | 02:55 PM
OCMerrill's Avatar
There is a relay. Fried contactors inside the relay can reduce the voltage or available amperage to the pump. Replace the relay and see if your problem goes away.
Old Feb 25, 2010 | 05:26 AM
Dieselhed's Avatar
Is this something that can take some time to fail, or would it go out all at once?
imbodie
21
Jan 8, 2024 08:49 AM
nitrousn
Jan 24, 2010 08:19 AM
O791challenger
Apr 29, 2009 07:27 PM
graynn
Mar 26, 2008 08:00 PM
CapnRam
13
Feb 22, 2006 09:23 PM
