How do I reset eng code on 2006 5.9
Old Oct 26, 2010 | 05:32 PM
travelingman's Avatar
I had removed the breather tube to get to the oil filter while serviceing the trk . So I disconected what i'm guessing is the Mass Air Flow sensor when I did that . Well I restarted the trk before I hooked that back up , an of course
the little engine Icon stayed on . I shut it off hooked it back up restarted but now it want go off. How do I reset this .it does like the book says an after about 15 sec it flashes 5 times but stays on after start ? My son suggested unhooking the batterys an letting it set a while , I could resync my trottle after that , but is that the only way to reset a code ?
Thanks George
Old Oct 26, 2010 | 08:20 PM
rockcrawler304's Avatar
I'm not sure what you actually disconnected but as long as everything is back to normal, after a few key cycles it should clear itself.
Old Oct 26, 2010 | 08:31 PM
DodgeChallenger's Avatar
George - I unplugged mine on my early 07 to out a K&N kit on and it did not have the Check Engine light on at all when I started it up again. I di not have the batteries disconnected either.
DodgeDiesel61
Apr 14, 2013 01:57 PM
DodgeDiesel61
Apr 14, 2013 09:00 AM
travelingman
Oct 29, 2010 12:31 AM
NJMurvin
May 10, 2004 06:00 PM
