HELP w/Oil Analysis sample
Old Jan 3, 2010 | 06:33 PM
hector's Avatar
Originally Posted by billie
Sorry to bring this up again, but is there a problem with doing it at the filter?
I don't know. The instructions on the test kits( that I use) state to do a clean catch at the drain
Old Jan 3, 2010 | 06:42 PM
hector's Avatar
Originally Posted by Danderson
Yeah,the Fumotu cures the "deluge or nothing" factor on the 3rd gens. Killer setup and quality.
it would be nice if the outlet was threaded so, you could install a small plug to stop up the hole. Just incase the lever were to open . Also, my drain plug is flush with the botton of the oil pan.I sure would hate to knock this valve off going off road..I was also looking at the Fram sure drain system. I use to have it installed on several of my vehicles. I don't think it's made anymore
Old Jan 4, 2010 | 10:22 AM
Lost Lake's Avatar
You may be able to do it at the filter, but I'd let the testing facility know where you got the sample. Remember that the filter is full of all the crud, so oil from there could be the dirtiest.
If I were running extended and needed samples, I'd put a second drain plug in with an extension tube that reached into the pan to the midpoint of the oil level and draw my sample from there. Otherwise just pull a sample from the drain pan with a valved drain and pour the extra oil back into the engine.
Old Jan 4, 2010 | 11:22 AM
6spd05Dually's Avatar
This is incorrect.
The best way to capture a "real world" sample is to use the draw tube through the dipstick tube on a hot engine just shut down. I also have the same issue with my 06, so I resorted to a mid drain capture, got a base line and extended from there.
The reason you want the sample from the oil pan after the engine is at full operating temp and just shut down is because that is when the contaminants are in full suspension. If you draw a cold sample it will be inaccurate.
You're right! Not sure why I said oil pan isn't the best place. I corrected my original post.
Old Jan 4, 2010 | 11:37 AM
HL649's Avatar
I have an 06 and have taken a couple oil samples through the dipstick with no problems. I can't get the tube down the auto tranny dipstick tube bit the engine oil dipstick is fine.
Old Jan 4, 2010 | 08:36 PM
Which year of truck are you doing this on? My truck is a 2005. Also, what size tubing are you using?
Old Jan 4, 2010 | 08:40 PM
HL649's Avatar
I have an 06
I used a 1/4" tubing.
Old Jan 4, 2010 | 08:54 PM
HL, that is the same size I am using, but when I insert my tubing in dipstick tube it goes so far then hits whatever inside. What are you doing different? I bet the others would like to know also. Thanks buddy!
Darrell
ctd4stan
May 5, 2011 10:39 PM
Bigiron
Jul 24, 2008 10:18 PM
RDM16CTD
20
May 9, 2006 07:46 AM
marv h.
Feb 19, 2006 07:34 PM
2manydogs
Nov 3, 2003 09:37 AM
