Help - looking for part numbers / where to buy transfer case-drive shaft seals!
Old Jun 28, 2013 | 09:42 AM
nvr-enuf's Avatar
I have a 2004.5 ram 4x4 in which I had removed the two seals that go into the back of transfer case.
I am having a hard time ordering the two seals - one is like a big cup dust cover that presses into the back of the transfer case in which the drive shaft slipps inside. Once that dust cup seal is removed, there is another seal that seals onto the drive shaft input yoke shaft as well, it looks like a typical axle shaft seal.
Anyone that can help me with the part numbers / where to buy, please let me know.
I believe my input shaft OD is around 2.3" in diameter.
thanks
SAS
Old Jun 28, 2013 | 01:05 PM
nvr-enuf's Avatar
The big cup dust cover seems to be dodge part number 05086341AA, does anyone know if this includes the inner seal that looks like an axle seal?
Old Jun 29, 2013 | 10:52 AM
Hintonc393's Avatar
Rockauto.com, they have what you need.
Old Jun 30, 2013 | 09:09 AM
nvr-enuf's Avatar
I changed the carrier bearing to a non factory unit and replaced the year old precision and the bad u-joint with a SPICER 1410 u-joint - truck is smooth as silk.
Bottom line, I am sold on the spicer u-joints.
Old Jul 1, 2013 | 07:52 PM
Roadmedic's Avatar
Where did you get the non dealer carrier bearing?
Old Jul 15, 2013 | 01:14 PM
nvr-enuf's Avatar
The company that replaced the u-joints (universal driveline) in Fond Du Lac, WI ordered the carrier bearing. I want to say it was around $70. I think I still have the receipt in the truck, i will look tonight.
Diesel Head
Mar 17, 2012 08:21 PM
95black2615
Sep 9, 2008 05:28 PM
qwest
Jul 21, 2007 10:38 AM
Bobcat698
16
Nov 5, 2005 08:44 PM
