Help---Dodge Ram CTD Engine Codes
Old Jun 17, 2006 | 10:26 AM
vonzoog's Avatar
My 2004 CTD is showing an engine code of P0868.
The list I have does not show this number. However the list I have was printed from a Durango. Are all DC products using the same codes? Would a Jeep Liberty, Dodge Ram, etc. be using the same codes?
Any info on this would be appreciated. And does anyone know what the P0868 means?
Thanks,
Old Jun 17, 2006 | 01:24 PM
crobtex's Avatar
Look here. It says it's something about trans fluid pressure low.
Old Jun 17, 2006 | 03:50 PM
Artie04's Avatar
Here is what 04 Power Train Diag manual says about the code:
Symptom:
P0868-GOVERNOR PRESSURE SENSOR VOLTS TOO HI
When Monitored and Set Condition:
When Monitored: Continuously with the key on and the engine running.
Set Condition: This code will set when the voltage from the governor pressure sensor is
above 4.89 volts for 8.5 seconds.
POSSIBLE CAUSES
OTHER TRANSMISSION DTC’S PRESENT
PARK NEUTRAL DTC PRESENT
GOV PRESSURE SENSOR SIGNAL CIRCUIT OPEN
SENSOR GROUND CIRCUIT OPEN
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE
GOVERNOR PRESSURE SENSOR SIGNAL CIRCUIT SHORT TO OTHER CIRCUITS
GOV PRESS SENSOR SIGNAL CKT OPEN INSIDE TRANS
SENSOR GROUND CKT OPEN INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE INSIDE TRANS
ENGINE CONTROL MODULE
INTERMITTENT WIRING AND CONNECTORS
798Lady
Dec 14, 2010 11:48 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
