help with code 191 fuel rail
Old Nov 30, 2006 | 10:46 AM
brickenbone's Avatar
need help finding out problem with code 191 fuel rail pressure sensor circut,range or performace problem. Anyone know what I got going on?
Old Nov 30, 2006 | 03:13 PM
Smkn600CTD's Avatar
Sounds like you've pop'd the Fuel Rail Pressure Limiting Valve.
Its common on trucks that run pressure boxes too high. Pricey too.
Old Nov 30, 2006 | 05:04 PM
coobie's Avatar
If I am correct,if you keep the BD powerpup in the lower settings is does not use pressure,just timing.coobie
Old Nov 30, 2006 | 05:54 PM
yes it am just on the low settting, runs fine...
Old Dec 1, 2006 | 08:11 AM
Nomo stocker's Avatar
My truck is going to the dealership for that same code today. I'll let you know what they say. My stock truck has always got crap mileage.
Old Dec 1, 2006 | 09:26 AM
CD in NM's Avatar
I experienced that code at about 2K. I was stock - no box. The dealer claims that it occurs because you had the key on too long without starting the truck and it sets off a low pressure code. Mine actually happened while driving, so you tell me? I started researching what it COULD be all about after the lame stuff from the dealer. I picked up a rail pressure kit (plug and some hoses) just in case the valve opened again and stuck open leaving me without rail pressure along side the road. This is the actual problem with the valve when you throw the code during driving-it stays open a tad longer than it should.
I have not had the problem re-occur since, but I am not taking any chances, so I have the kit for a roadside repair. There is someone who has modified the valves and is selling them/or getting ready to sell them. Very expensive, kit was cheaper. If you add a pressure box you will end up capping the rail because of the valves limits.
CD
Old Dec 2, 2006 | 09:21 AM
Bricken, the dealer told me there was a reflash for a 191 and performed that on my truck. On a side note they put 80 PSI in all my tires for my poor mileage complaint. Well I guess they did something.
Buckshotram
May 12, 2008 10:33 AM
king d
Aug 5, 2005 05:24 AM
boughtadodge
40
May 6, 2004 10:46 PM
boughtadodge
Apr 7, 2004 06:42 AM
