harmonic balancer, can i remove and never reinstall?
Old Jul 4, 2010 | 09:02 PM
jmlcolorado's Avatar
Well ive been chasing a vibration in the drive train for over a week. Replace one u-joint with no luck stopping it. Tired of checking everything, i put the truck on jack stands and geared it up to 50mph to see if i could find anything.
Found my harmonic balancer on the front of the diveshaft rotating out of square. I stopped the truck and grabbed it and found i could move it back and fourth by hand.
The rubber is all dry and failing. I called dodge to see if this is a replaceable part which it is not. I'd have to buy an entire new drive shaft.
My question is can i just cut this thing off and not put a new one on and be okay with that?
I might be pulling the trigger on a 1 piece drive shaft after i talk to my drive shaft guy after the holidays but if it ends up being too pricey, is my alternitive a bad idea?
Thanks guys.
Old Jul 4, 2010 | 10:10 PM
Bark's Avatar
Sorry that I dont know a thing about the balancer but was bored and found a couple of posts that might give you a little more info.
https://www.dieseltruckresource.com/...cer+driveshaft
Hopefully those in the know will chime in. Meanwhile, make sure to keep us posted
Old Jul 5, 2010 | 12:49 PM
Thanks for those links. I did catch both of those threads before I posted mine. I have a call
Into my buddys drive shaft guy to get his opinion about just cutting
The thing off. I'm not really sure why its there since I havnt generally seen many
Drive shafts with them. Maybe it has something to do with it being a split shaft design.
I think I might have the drive shaft guy quote me to build a 1 piece shaft utilizing the factory u joints that way I can still go to a parts store to look em up rather then trying to remember a part number.
Anyone know the diameter of the 07 and up 1 piece shafts made from aluminum? I know their quite larger due to the material. I'm guessing at least 6" but that's just a guess.
Thanks for your input.
Old Jul 5, 2010 | 02:15 PM
15 Digger's Avatar
Thanks guys.
The harmonic balancer is on the front of the engine crankshaft. The bearing on the driveshaft is the carrier bearing on 2 piece driveshaft. if that is so worn you see it wobbling around that is your problem i'm sure. There are also 1 piece replacements guys are using. The carrier bearing can be replaced.
Old Jul 5, 2010 | 02:56 PM
Condor's Avatar
I believe he's talking about the balance weight on the front of the driveshaft.
When I replaced mine with a one piece I got it without the weight and it has been fine FWIW.
Old Jul 5, 2010 | 03:40 PM
NickBeek's Avatar
My factory DS does not have the balancer on it. I don't know why some have them and some don't.
Old Jul 5, 2010 | 05:41 PM
Bark's Avatar
Thats what confused me! I had never heard of an H balancer on a driveshaft until recently.
Old Jul 5, 2010 | 05:53 PM
Here's a picture of the culprit.
From what i gather, the short beds dont have them at all. Only the long bed crew cabs with a 2 piece shaft.
Condor, have you seen a factory setup with the ballancer? Im asking cause i wonder if everything else is the same.
Attached Thumbnails harmonic balancer, can i remove and never reinstall?-getattachment.jpg
Old Jul 5, 2010 | 10:57 PM
NickBeek's Avatar
Not all long bed quad cabs have the balancer on the DS, mine doesn't.....
Old Jul 5, 2010 | 11:15 PM
What year is your truck?
Old Jul 6, 2010 | 04:49 AM
Condor's Avatar
You could order the DS with or without the weight.
Old Jul 6, 2010 | 01:33 PM
15 Digger's Avatar
Never saw one of those. Maybe Dodge did it in response to the chatter on acceleration that some were having with 2 piece shafts.
Old Jul 12, 2010 | 09:37 PM
Im pretty sure that chatter is from the carrier bearing which is also a poor design.
So....... Anyone knowif i cut this thing off completly, will that have any poor results? besides making the shaft out of ballance?
Old Jul 12, 2010 | 09:54 PM
roughstock's Avatar
if you remove it, id get the entire driveshaft balanced.
Old Jul 13, 2010 | 04:45 PM
NickBeek's Avatar
My truck is an '06 quad cab long bed manual trans truck.
BTW, I just noticed my signature is missing. Anyone know why that is?
