Guage wire routing tip
Old Aug 18, 2009 | 11:26 AM
Rush Rider's Avatar
I finished up the overhead 3 guage setup this weekend and had a bit of a tough time figuring where to feed thru the firewall on my 06 2500, well after looking at it a bit I noticed a simple block off plate for the clutch master cyl. at the pedal cluster, well I removed it and drilled a 7/8 " hole installed a goroumet and bolted it back to the firewall (2 nuts inside) and ran the wires thru neatly. this tip will only work for the auto trans guys.
Mike Bruns
Old Aug 18, 2009 | 11:45 AM
05 CTD2500's Avatar
Yep thats where I ran mine too, you can always buy a new plate if you need to put it back completely stock.
piston
Feb 3, 2005 11:37 PM
RAM2940
Jan 11, 2005 12:38 PM
kd460
Feb 16, 2004 09:49 AM
SilverDiesel
Jan 1, 2004 03:14 AM
TPilaske
16
Nov 22, 2002 08:15 PM
