Grid heater ?
Old Feb 7, 2007 | 12:34 AM
Mule Man's Avatar
Grid heater ?
It has been cold enough here in the desert to cause activation of the grid heater. It is also warm enough in the afternoon to use the AC. I have noticed if I leave the AC on and the blower my truck will start to crank then stop, kinf of like a low battery. Turn off the AC and it fires right up. MY question is this normal or do you think I may have a battery going down. I was hoping someone might give it a try and let me know if perhaps both on at the same time may be too much draw on the batteries. The amp meter reads 14-15 when running. My truck is a little over a year old and well maintained.
If you have the time...Thanks
Old Feb 7, 2007 | 03:13 PM
Mule Man's Avatar
Someone? I just need you to try and start your truck with the grid heater on and the ac and blower motor.
Old Feb 7, 2007 | 03:23 PM
belgianmagic's Avatar
THATS NORMAL ...your saying when you start the truck with the ac on high ...the blower fan goes ~HI~LO~HI~LO... the alt.doesn't kick in for a few to 20 seconds after starting
NO WORRIES !
Old Feb 7, 2007 | 03:25 PM
THE COMBINATION ...GRID HEATER STILL CYCLES After start (heavy draw)and the blower, and the alt not kicking in yet ...its normal
Old Feb 7, 2007 | 06:53 PM
Mule Man's Avatar
No, it begins to crank and then stops. It will not turn over enough to start the engine. If I turn off the AC, it cranks fine, starts, and runs fine.
Old Feb 7, 2007 | 07:54 PM
djbikeman's Avatar
That's not what he's asking.
In our trucks, when the defrost is on, the AC is on. I start mine every now and then with the defrost on in temperatures where the grid heaters are active, and it turns over fine. I usually turn everything off if I see the WTS light on, just in case.
What you're experiencing doesn't sound normal to me.
Old Feb 8, 2007 | 12:00 AM
Mule Man's Avatar
Thank you!
Old Feb 8, 2007 | 12:29 AM
MCummings's Avatar
You probably need new batteries.
Merrick
Old Feb 8, 2007 | 12:34 AM
Mule Man's Avatar
Batteries have always lasted at least 2 years for me. I will see what the dealer says about the prorated warrantee.
Old Feb 8, 2007 | 12:58 AM
DrDiesel's Avatar
Wink
I think they had an update for this complaint.
There maybe a flash calibration to turn the A/C compressor of when cranking/starting.
Old Feb 8, 2007 | 10:29 AM
Mule Man's Avatar
Thanks for that info. I will add that to my questions. I hope my AFE dos not void my battery warrantee. :>0
SpeedyWS6
15
Feb 2, 2011 07:22 PM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
Dodgezilla
Mar 13, 2003 06:14 AM
Chewy
Dec 18, 2002 06:46 PM
