Gear Ratio and PosiTraction Information
Old Aug 15, 2007 | 08:59 AM
davedye's Avatar
I bought a used 2006 Dodge 3500 Dually privately. How can I find out if it has a 3.73/410 rear and if it is positraction???
Thanks
Dave
Old Aug 15, 2007 | 09:28 AM
donnee's Avatar
There should be a tag on the rear end that will state what the gearing is.
If thats missing, look on the glove compartment door aas there should be a paper that states the gearing.
If all else fails, request a build sheet from the dealer.
I would venture a guess and say you probably have 4.10s.
Old Aug 15, 2007 | 09:36 AM
Raspy's Avatar
I don't think they are tagged anymore. Look at the spec sheet in the glove box. If the gearing is not mentioned I think it's 3:73, if it is mentioned it will say 4:10. Same is true for the trac-lok. No mention, not there.
The other way is to post your RPM at 60 in sixth, or OD if its an auto, and someone will chime in with the answer.
John
Old Aug 15, 2007 | 09:56 AM
Hounddog's Avatar
No tags since 03.Any Chrysler dealer can pull a build sheet for you.
Old Aug 15, 2007 | 12:51 PM
raycarlson's Avatar
tag in glove box will give you three letter-digit option codes(G3U,DR3,etc)both posi and non-standard gear ratios will have an option code which you can check on in a dodge sales website under build your vehicle
acook
Apr 10, 2006 02:07 AM
Shepherd57
17
Jul 14, 2005 06:29 PM
efbeason
May 24, 2005 10:03 AM
Andrew k
May 11, 2005 10:17 PM
mbw
Mar 5, 2003 05:38 AM
