g56 conversion
g56 conversion
well pulled the trigger on the parts to do the swap. going from 48re to g56. Buddy in Texas is storing the parts until I can get out there to do it. CD in NM gave me her driveshaft out of her truck since she went to a 1 piece.
bought the wiring harness for $86, shift boot for another $86 (those will be here today).
tranny
bellhousing adapter
clutch pedal, linkage
stock clutch/dual mass flywheel (going to install a SB 3250 DD though)
upgraded hydros
main harness
Looking foreward to the swap. going to lay out all the parts first to make sure I can do this in a single day. Already contacted Bob Wagner to update the ECM to make it think it is a manual. Have a good friend that runs a wrecking yard looking for a steering column.
going to be selling my entire 48re set up as a package deal for someone who wants to convert theirs to auto. My tranny is 2 months old.
tranny
bellhousing adapter
upgraded hydros
main harness
You going to do the swap out in Tejas ?? I was looking forward to driving up and watching, maybe lending a hand or handing tools . .
I suppose after this it will be the S T R E T C H . . . that I have to see too. Lemitar is just an hour and a half away.
CD
CD
I want to do the same conversion myself. What is the total cost you have in it so far? I have a rebuilt trans with ATS internals, but I don't enjoy how harsh the shifting is when I turn the Smarty down for daily use. I would really enjoy the read if you keep this updated so those of us who do want to follow in your footsteps know what to expect.
it will be done here in town Carol. I have to go to tejas to get them as Lucus met the guy that was selling them and is storing them in his barn for me and lookin for a couple of small items I still need. Getting the harness and shift boot today. Crossing my fingers that the harness that I ordered is all i need or I will be on the hunt for the other side to complete the electrical side of the swap.
just bought clutch pedal, pin, bushings, c-clips, shifter boot, body boot (from body to the 2nd boot) all for less than $75 from the dealer.
Figured since the tranny came out of an 05, I was not going to take any chances of the shift lever being the same or not especially with the price I just got it all for brand new.
part numbers for clutch pedal etc
shaft (pivot shaft) 52010318aa
snap ring (need 2) 6023879
bushings (need 4) 52010309aa
pedal with rubber pad 52009944ac
clutch pin (where master cyl attaches) 52010331ac
shift boot (thru metal floor) 55366042aa
shift boot (top boot that looks good) 55398764aa
transmission/t-case harness (for electric shift tcase) 56041432ab
Headlight to dash harness 56051333ae
this site has good prices. type in the part numbers and add to cart.
http://www.moparpartsamerica.com/spl...?siteid=214583
Awesome Chris!! If you need me to take any pics of mine or check wires to make sure you get it right the first time just let me know. Wish I could go up there to help with the swap but I bet it won't work out for me time wise.
So will the Smarty flash for your ECM allow you to run stock tuning if you want/need to?
Good luck on the swap. The .79 OD will be great for the 37's (or larger) you must be running with 9" of lift.
Chad- I will let you know when we do the swap and thanks for the offer brother
AH64- I have talked to Bob and he is ready to email me the program to make mine think it is a manual. said he has done many of them
clutchless- I chose the g56 cause i got a KILLER deal on EVERYTHING (minus the goods required for 06-07). the tranny I got came out of an 05 with 100k on it. bone stock, even stock air cleaner. had a buddy in east tx check it out at 1am for me and said shafts are VERY tight, no abnormal play, fluid looked killer and have the bellhousing adapter (between the block and tranny as it is different from the auto to the manual), stock clutch, pedal, harness (but for an 05) and shifter.
I will post pics of the progress. I want to lay everything out next to the truck before we even start to make sure we can do this in 1 day, 2 max to be on the road. Going to order a southbend 3250 dd with hydros.
After I am done, I will be selling my entire setup so if somone is interested in doing an auto conversion, my tranny is only 2 months old (got it fully rebuilt a couple months ago while under warranty including the converter).
