Fuel Pedal
Old Nov 24, 2008 | 07:00 AM
95Z28A4's Avatar
Fuel Pedal
I've used the search, but can find the information I need. Maybe I'm searching using incorrect terminology. So, here it is..........
I purchased a new Cummmins QSB3.3TAA from Cummins Central Power to install in a 1995 Jeep Grand Cherokee (ZJ). The QSB3.3T has a CM2150 ECM and uses drive by wire similar to the ISB's in the Dodge trucks. The CM2150 calls for a Throttle Position Sensor, Idle Validation Switch, and electronic fuel pedal/lever.
A Cummins rep at Central Power suggested the fuel pedal assembly from an 04+ Dodge may work for my QSB3.3T. I purchased Dodge part #53032753AC used with plug/pigtail from a 2006 Dodge 3500. It is being shipped, but I have not yet received it.
My question is: Does Dodge part #53032753AC fuel pedal assembly contain a Throttle Position Sensor, and Idle Validation Switch?
Thanks
600 Megawatts
Mar 26, 2008 07:09 PM
serious
Mar 6, 2006 07:06 PM
HOHN
Oct 18, 2004 11:48 PM
Cummins600
May 12, 2004 03:41 AM
admin
Jan 19, 2003 08:35 AM
