Fuel mileage issues and dealer problems
Old Jan 18, 2010 | 06:37 PM
  #31
Spooler's Avatar
Originally Posted by DBLR
Wow even at -24 below zero, extra warm up time for cold weather, snow and ice roads, new aggressive traction tires the lowest I have gotten so far for combo driving this winter is 14.95 mpg. After you change out your fuel filter (use either the Fleetguard Stratapore FS19856 or the Baldwin PF7977) it may be a good idea load 2500 Lbs in the bed or hook up to a loaded trailer with no less then 4K and drive your truck for a few hours to heat up the engine and burn out the carbon that could be build up on the injectors and piston tops. It may be a good idea to also use a fuel additive at the same to help out.
JMHO
You are correct. Towing heavy will fix a MPG issue with the quickness. I tow heavy once every 1 month and a 1/2. Keep everything working well and carbon free....LOL
Old Jan 18, 2010 | 08:23 PM
  #32
kkime's Avatar
I have been using that Baldwin fuel filter pf7977 and Fram paper air filter and now using the power sevirce again and will try this out for a while. My daily trips are usually 8-10 miles somedays and then 30-50 other days.
Old Jan 18, 2010 | 08:29 PM
  #33
kkime's Avatar
Also I dont pull anything heavier than my 20 ft fiberglass bass boat right now, I sold my heavy fithwheel before buying this truck,
Old Jan 19, 2010 | 03:28 PM
  #34
DBLR's Avatar
kkime,
Well if you have a Loews or Home Depot near by then every 40-45 days on a Friday night go buy load of cement blocks (at least 2500 lbs worth) an load them in the bed of the truck, if you have a trailer buy 3-4 ton worth of blocks. Saturday drive it for 3-4 hours non stop, on Sunday return the blocks for a refund.
Old Jan 20, 2010 | 12:47 PM
  #35
Lost Lake's Avatar
kkime,
I can get 10 mpg in the city if I have my foot in it!!! I usually get my best mileage in the city though, on long streets at 40 mph, I get amazing mileage, kind of like long flat roads at 60...
I'd like to take it on a race track and just run it at 50 or so and see how high my average would go.....
Old Jan 21, 2010 | 12:09 PM
  #36
kkime's Avatar
question Im about to by that heater cord but I cannot find where it goes or plugs into, I removed my airbox and have searched around and cant find any wire at all that it might plug into.
Old Jan 21, 2010 | 12:36 PM
  #37
ssandlin's Avatar
Check the sticky in the 3rd Gen Non-Drivetrain forum
Old Jan 21, 2010 | 03:02 PM
  #38
DBLR's Avatar
Its to the left and above the oil filter you should see a black cap covering where the plug hooks up that you need to remove so that you can hook up the cord.
Old Jan 23, 2010 | 04:32 PM
  #39
SCDAYTONA's Avatar
The mileage in my 2006 mega Cab Dualie is poor as well. I just chalked it up to it's the way it is. Mine has the HO motor with an Auto, 3.73 gears, AFE Air Filter set up and Super Chips Programmer. I get around 14 driving to work all back roads and on the highway doing 70 or above it gets 15. Pulling a 28 Foot trailer at about 8500 lbs on the highway, I get slightly over 10. Tried all the settings on the Super Chips programmer except the new economy mode which I just found out about as well as stock and it seems to do the best on the performance setting. My old 97 with 3.55 gear stock would go 17-18 on back roads, 23 on the highway and 15 pulling my trailer, but it is no comparison to this truck in power and comfort.
Old Jan 23, 2010 | 10:20 PM
  #40
Speedfreaks101's Avatar
Add me to the list. I have a stock 6 speed, 06 quad cab, 4x4 and the best mpg I have ever been able to get was 18 going 60 mph for 300 miles. My truck came with 245/70-17's and I am considering going to 235/80-17/s to help a little. 60 mph is right at 2000 rpm. At 70 I get about 13-14mpg.
Old Jan 25, 2010 | 07:50 AM
  #41
ssandlin's Avatar
You must have the 4"10 rear end if at 60 mph your turning 2000 rpm. I have the 3:73 rear end, and at 70 mph, I'm turning 1950 rpm. Assuming no head winds, I get 18 - 18.5 mpg at 70 mph. Pretty darn good for a 7000 pound truck.
Old Jan 25, 2010 | 12:28 PM
  #42
kkime's Avatar
I'm not certain but I think I got 3:73 becuase I only hit 2000 rpm around 72-73 mph and not sure at 60 but it's pretty low at 60, so I dont understand the poor mileage it doesnt add up to me.
Old Jan 25, 2010 | 03:17 PM
  #43
DBLR's Avatar
I wonder if how the engine was broke in makes a difference on how good or bad when it comes to fuel mileage...
Speedfreaks,
Every 2006 SRW truck I've seen in my area came stock with 265/70/17 tires.
The lowest mpg I've gotten this winter was 14.95 mpg during temps down to -27 below, today's fill up the mpg is back up to 16.1 mpg for 80/20 combo driving.
Old Jan 25, 2010 | 03:19 PM
  #44
kkime's Avatar
I dont know about that, I bought this truck it had 48k miles and now it has 52k miles, just trying to figure this one out since it is my first Cummins.
juspassinthrou
Jul 15, 2012 08:12 PM
lvmknsmoke..
Dec 2, 2009 05:21 PM
BigDave12768
16
Feb 4, 2008 09:03 PM
fflarry
Aug 25, 2007 10:39 AM
Andrew Martin
Oct 15, 2005 06:03 PM
