Fuel Filters
Old Oct 26, 2010 | 08:56 PM
DodgeChallenger's Avatar
Fuel Filters
My 2007 5.9 is the 4th Cummins dodge I have owned. I have never had anything other than a stock fuel filter system and have never had problems. My concern is that my luck could run out if this course continues as I read lots about the stock filter system being not up to par. So 2 questions come to mind that I would like to ask this forum;
1. what is the best (IE smallest micron) filter available for a stock 07 5.9 filter and will it suffice? I pull a 14000lb 5er up steep hills in BC Canada
2. Should I just put an aftermarket lift pump and filter system (eg AirDog or similar) on and be done with it? Up here a pump/filter system mounted to the chassis will need protection from salt, grime, sand etc that comes from the winter roads.
I need this truck to last as it gets good fuel mileage compared to the 6.7s and at the rate I put miles on it will take 10-15 years to get to the point I want to get rid of it.
Old Oct 26, 2010 | 09:22 PM
justin mcfall's Avatar
Baldwin 7977. It is a 5 micron
Old Oct 26, 2010 | 09:29 PM
Spooler's Avatar
Use the Baldwin, you will be fine unless modding it takes it's toll..LOL It's the Baldwin PF7977. I use them in my stock canister along with my Airdog 100.
Old Oct 27, 2010 | 12:10 AM
brassnadz's Avatar
Will that filter fit the 2003 as well? The dealer said they replaced mine before they sold me the truck, but I want to replace it anyway for peace of mind. Id like to get a 5 micron or better.
Old Oct 27, 2010 | 03:07 AM
LeaperV12's Avatar
Yes
Old Oct 27, 2010 | 08:36 AM
rufushusky's Avatar
Yes, the PF7977 fits all 2003-2007 5.9 Common Rails.
Old Oct 27, 2010 | 11:22 AM
mossyoak11's Avatar
where can we get the 7977? any reputable sources/the best price?..
surfram's Avatar
The Hastings FF1260 is the alternative to the Baldwin PF7977.
Old Oct 27, 2010 | 11:37 AM
rufushusky's Avatar
I get mine at fleetpride but you can look them up here:
[http://baldwinfilters.com/distributorlocator.html
Old Oct 27, 2010 | 12:31 PM
lastcall190's Avatar
Grainger sells them too
Old Oct 27, 2010 | 04:02 PM
Danderson's Avatar
www.blinefilter.com. $11.61 ea.
Old Oct 27, 2010 | 04:37 PM
OldDodgeOwner's Avatar
In the stock canister, I run the Baldwin PF7977. I also have a 2 Micron Donaldson P551313 filter plumbed inline between the stock filter canister and the injection pump. Kind of expensive changing filters, but cheap peace of mind for a $3000 set of injectors.
Old Oct 27, 2010 | 05:16 PM
rufushusky's Avatar
Yes sir. How much are you paying for Donaldsons? I got mine at a Cat dealer for like 6-7 bucks...
Old Oct 27, 2010 | 05:58 PM
My records show I paid $7.30 a piece for them. Can't remember where I got them though.
Old Nov 2, 2010 | 07:47 PM
zachv's Avatar
If we have the stock fuel pump on an '05 can we run the 2 micron additional filter between the stock filter canister with a PF7977 in there? Will it not drop fuel pressure too much?
