Fuel delivery issue
Old Sep 8, 2011 | 08:57 AM
Ron_shop_super's Avatar
Fuel delivery issue
I just bought a 2006 3500 hd with a 6 speed, it has a couple issues but i've not worked on anything this new. The symptoms are! seriously don't laugh When starting the truck it cranks 2 to 3 seconds which is longer than i think it should be, after it starts there is NO smoke or engine miss it runs good. Now when driving in town or under normal conditions it does OK but when you hit the Interstate it acts sluggish and weak and will throw a fuel delivery code PO148 and you can hear a slight fuel knock but it still does'nt smoke. Now the wait to start light is coming on while driving and staying on, I figure that is just a sensor or wiring. What I have done so far is service the truck and replaced the filters, checked my lift pump. When cranking it was getting about 12 to 15, when slow idle it was about 8 to 10 and at full trotlle it dropped off to about 2 to 5 all lift pump pressure. Can I get some advise not sure where to start on this 3rd gen engine. Did I mention it gets terrible fuel mileage, 10 to 12 mpg.
Old Sep 8, 2011 | 09:54 AM
BigIron70's Avatar
Cummins Guru
You might want to recheck that code, no such code that I can find in ECM module.
Old Sep 8, 2011 | 10:30 AM
Sorry the code is a PO148 fuel delivery error
Old Sep 8, 2011 | 12:35 PM
BigIron70's Avatar
Cummins Guru
That narrows it down to this.
Possible Causes
OTHERS DTC'S PRESENT
FUEL LEAKS
FUEL CONTROL ACTUATOR
FUEL PRESSURE SENSOR
CASCADE OVERFLOW VALVE
CHECK VALVE DAMAGED OR BLOCKED
FUEL RETURN LINES OBSTRUCTION, DAMAGE, OR DEBRIS
LIFT PUMP FLOW
AIR IN FUEL SYSTEM
LEAKING FUEL INJECTORS OR HIGH PRESSURE CONNECTORS
PRESSURE LIMITING VALVE
HIGH PRESSURE FUEL PUMP
INTERMITTENT CONDITION
Old Sep 8, 2011 | 12:40 PM
BigIron70's Avatar
Cummins Guru
Check fuel for any contamination, fuel filter. DO you have long crank time? engine running rough? lack of power? engine rpm fluctuating or hammering engine noise? Black smoke? fuel leaks?
Old Sep 8, 2011 | 02:09 PM
It has a new fuel filter the tank is full of fuel, It doesnt smoke and yes it does have long crank time. Yes i do have a fuel knock AKA hammering noise
Old Sep 8, 2011 | 02:10 PM
I need to narrow the problems how do I do that
Old Sep 8, 2011 | 05:35 PM
The engine is not running rough, It is lacking power, and there are no fuel leaks
Old Sep 8, 2011 | 06:25 PM
BigIron70's Avatar
Cummins Guru
If you can monitor your fuel rail pressure when running that can help diag. Does fuel pressure fluctuate more then 500+or- at idle?
Old Sep 12, 2011 | 10:33 AM
I dont have anyway to link to the ecm that advanced, And my fuel line on my gauge is to short so any other suggestions.
Old Sep 12, 2011 | 11:59 AM
highmileage's Avatar
sent you a private message
Old Sep 12, 2011 | 02:39 PM
Thanx I will try these out.
dieselnewbie
Jan 7, 2015 10:25 AM
MKELLY
Aug 29, 2007 08:47 PM
piesterdodge
Aug 16, 2003 04:59 AM
kfleuret
Jun 18, 2003 08:22 AM
Lil Dog
Jan 11, 2003 02:00 PM
