Fuel Additives
Old Dec 3, 2006 | 09:39 PM
  #31
jpajax's Avatar
Put a mix of 4oz. of two cycle low ash oil and 8oz. of mmo to tank of fuel. I seen a post that ask if mmo had sulfer in it and I look at the gal. bottle and it had a sticker on it that said that it contained sulfer.
Old Dec 4, 2006 | 02:38 AM
  #32
LVTony's Avatar
I use fuel additives because I think the minimum lubricity standard for ULSD is too low (max scar diameter of 520 microns based on High Frequency Reciprocating Rig test method).
Sure the engine will be fine. I'm more worried about the CP3 and injectors. Will they wear prematurely? I don't know. I expect it's probably only the difference between getting 150,000 miles on the engine (and pump/injectors) and 300,000 miles. Most people won't care, but I had my last truck for fifteen years, and I plan on keeping this one a good long time too.
We should have had the ULSD limit match Europe's 460 microns HFRR limit (more lubricity). Bosch seemed happier, and they should know what's better for injector pumps.
Tony
Old Dec 8, 2006 | 05:59 PM
  #33
06megacabman's Avatar
I've been using the John Deere Winter combined with 8 oz of MMO for the last 3 tanks. Can't get the Stanadyne easily around me would have to order online. I can get the John Deere just down the street and according to the Stanadyne report they are almost equal.
Truck definitely idles smoother and quieter but my mileage has dropped off some. Could be the winter fuel switch over at the same time I started using the additive. I have 3500 miles total on her so far.
Old Dec 8, 2006 | 06:22 PM
  #34
LanceK's Avatar
I noticed a slight drop in fuel mileage when using the Stanadyne (summer months). I think someone said something about it being a result of higher cetane? I also use Hess which has a minimum of 42 cetane.
Old Dec 8, 2006 | 08:05 PM
  #35
Boomer58's Avatar
Some Big Lots have the genuine Cummins brand diesel fuel additive $1.50 a quart. The Hampton,Va store has been cleaned out Mike
Old Dec 8, 2006 | 10:22 PM
  #36
dspencer's Avatar
I use primrose Flow-Master 409 on the really coldest tanks and 405 on the rest. Most of the time here in N Texas the 405. It doesn't get cold much here.
Get it here http://store.avlube.com/addiga.html
Old Dec 9, 2006 | 11:38 PM
  #37
toyhaulersdream's Avatar
Use Lucas myself
Old Dec 9, 2006 | 11:55 PM
  #38
06dually's Avatar
I'm a believer in Stanadyne....runs smoother.
Old Dec 10, 2006 | 12:26 AM
  #39
BEARHUNTER's Avatar
From: Well I thought I lived in America, but its looking more like france every day.
Wow, all this info and choices to make. Me I stay away from MMO and 2 stroke, just use an additive like stanadyne, power service, or howes. it will do fine. In fact im sure it will be ok with out an additive. says in your owners manual your engine doesnt need it. but what does cummins know? I saw in some other posts that alot of guys started to use 2 stroke because of the vp44. our trucks dont have that. Also im wondering if a dealer knew that 2 stroke or mmo has been used and would not fix a failed fuel sytem part because of that? any experiance with that? just wondering?? ive read that they wont fix sometimes if water is found in fuel system.
Luke S your a dealer. have you ever heard of warranty work problems if other than normal fuel additives are used and a part fails?
Old Dec 10, 2006 | 06:08 AM
  #40
usernames_taken's Avatar
I don't feel the need for any additives here in texas...also can't justify the extra cost if the additive doesn't improve mpg. According to various sources the ULSD has plenty of lubricity for pre 07 engines.
Old Dec 11, 2006 | 01:34 PM
  #41
FishingFather's Avatar
I use about 8 oz of Power Service per fill up. I buy it by the gallon at Walmart and measure out into a smaller container for fill-ups. The truck seems to run a bit smoother with it. Plus I like the peace of mind thinking it might be helping the truck live longer.
Old Dec 11, 2006 | 03:53 PM
  #42
Nascarcamper's Avatar
I have used Dexron Trans Fluid a couple of times, seems to make thing quieter, have not heard of any ill side effects, couple of friends with big rigs use it all the time, anybody heard anything about it?
Old Dec 18, 2006 | 01:37 PM
  #43
DBLR's Avatar
IIRC back in the 70's they said unleaded gas would not cause any problems with the older engines that used lead in the gas and yet it sure did screw up the valve train in many cars and truck. I’ll play it safe and add extra lube to every tank of fuel as I sure don't trust what they have to say. Are these not the same people who screw us back in the 70's with the gas change over? My self I get and extra 1-2 mpg with additives so it pays for it’s self in my case any way.
Oh and BTW trans fluid should not be used in a newer diesel engine as it can screw up the injectors. Yes you could use it back in the older diesel engine but it shold not be used with the Bosch cp3 system.
JMHO
Old Dec 18, 2006 | 11:01 PM
  #44
genesag's Avatar
I use Amsoil Diesel fuel concentrate and it works great. I've used it in my '92, '96, '99, '02 &'03; all past 100,000 without any fuel related problems. Also I NEVER go anywhere with out Amsoil Cetane Boost since I got caught with some bad fuel in New Mexico 2 years ago. 4 oz in a tank full and my power and mileage were right back to normal.
____________________________
03 Q3500 Dually, Automatic, 2WD pulling a 36" Travel Supreme Triple Slide (16000# empty)
Old Dec 19, 2006 | 02:04 AM
  #45
3500lly's Avatar
Started using stanadyne a few weeks ago, I like it so far.
