front engine oil leak
Old Jul 8, 2015 | 09:01 AM
trik396's Avatar
i can't tell if it's the oil pan or above because the space is so thin. anyone have this issue or anything else like this?
btw she has 145k on her. well maintained
Old Jul 8, 2015 | 09:08 AM
BILTIT's Avatar
Mine is the same, pretty sure it is the front crank seal.
Old Jul 8, 2015 | 09:14 AM
trik396's Avatar
i can't imagine how much time it's going to take to fix if that is the case
Old Jul 8, 2015 | 09:17 AM
BILTIT's Avatar
From what i have read it is a lengthy process, the whole front of the engine (accessories) has to be tore down.
Mine is just a weep so i will wait alittle before i tackle it.
I have to do oil pan and valve cover gaskets too, might just do them all at once.
Old Jul 8, 2015 | 03:42 PM
BigIron70's Avatar
Cummins Guru
Front crank seal requires removing fan clutch and pulley with belt and tensioner. I would install seal with wear sleeve since crank is most likely grooved from seal. Use mopar gray silicone for cover. Not too difficult but cleaning old silicone does take some time.
Free89W350
Jan 5, 2010 06:28 PM
mr. ed
Oct 3, 2007 06:35 PM
Robertschas
Aug 19, 2006 02:34 AM
george7941
15
Aug 25, 2005 11:02 PM
Parvenu
Feb 1, 2004 06:06 PM
