front end binding
Old Dec 6, 2009 | 03:07 PM
herb101's Avatar
I did see today that as I held the brakes the front drive shaft did not move and the rear shaft moved in 4 high under a small load. While this was happening I can hear thrashing like it is skipping teeth in the tranfercase. Any thoughts and support would be awsome and thanks in advance.
Old Dec 6, 2009 | 04:46 PM
billie's Avatar
That should NOT happen. Hopefully just a busted chain and the housing, gears, etc survived but I wouldn't count on it, sorry. You could disconnect your driveshafts and play with it in neutral but I doubt it will tell anything more than what you know now.
Old Dec 7, 2009 | 01:46 PM
MichiganAxle's Avatar
You'll have to be a bit more detailed on this. Does this mean you applied the brakes and under a bit of throttle the front propshaft did not turn but the the rear propshaft turned?
Prop the front axle on jackstands, rear on the ground, put it in 4-Hi and turn the front propshaft. If it turns then then you have a t-case problem.
Do the same with the rear-only on stands with the trans in neutral.
I'm wondering if the lock-up hub, collar, fork its messed up. Cranking on that thing like you did in the sand just may have did those parts in.
Old Dec 9, 2009 | 10:37 PM
herb101's Avatar
I was on loose gravel and the back tires were turning a little and the front tires were not with the brakes applied. And I had a buddy do the same and saw that the front/rear shafts were not rotating in unison. Hope this paints a better picture to the mind for my lack of better words.
thank you
Old Dec 9, 2009 | 11:50 PM
billie's Avatar
If the shafts are not turning together in 4WD (hi or lo) then the TC is broken. Maybe a 1/4 turn max difference between them.
Old Dec 11, 2009 | 06:00 AM
herb101's Avatar
I do have all the tranfercase inner parts that were pulled off a 2000 model 2nd gen and I'm hoping that I'll find what I'm looking for.
Old Dec 15, 2009 | 10:27 PM
herb101's Avatar
Does anyone have a PDF file on the disassembly and assembly of the NP271?
Snowdog
Oct 14, 2011 07:17 AM
esde
Apr 14, 2010 06:41 AM
95black2615
Jul 22, 2006 02:19 PM
red24v
Mar 13, 2006 02:52 PM
dave78
22
Jan 5, 2006 06:09 PM
