Front Diff Temperature
Old May 22, 2008 | 01:51 PM
Tobin's Avatar
Originally Posted by enafzige
I've actually wondered that myself. I'm sure if I would have weighed the axles front and rear that the front would've been carrying more weight than empty...but I don't know how much that would effect the front diff temp.
One of these days, I'll hopefully install a dynatrack manual hub conversion kit and see if that eliminates the heavy towing/high front diff temp connection.
--Eric
The dynatrac kit should eliminate any temperature over ambient in the front diff. Nothing will be moving in there until you lock it in. My Ford's front diff is fully manual, and that is nothing but ambient temperature.
Tobin
Old May 22, 2008 | 11:38 PM
XLR8R's Avatar
Originally Posted by Tobin
120*F for the front diff and 105*F for the rear diff with a infared temp gun on the differential covers.
Tobin
Aiming inconsisencies? Hold the thing up to the diff and pull the trigger, its not like a sniper shot. I know the thing isn't too accurate, but what can it be +/- 10 degrees?
Tobin
Not necessarily operator error, although that contributes to the margin of error... and even at the +/-10* you mention there's an overlap between the front & rear covers of 5 degrees.
This is a case where infra-red measuring is good for relative temps, but not absolute temps. (i.e. you can only check front diff temp accurately against itself)
You could refill with 90W-140W and see if temp is different after the same drive in identical conditions.
afate45
Jun 7, 2014 12:08 AM
Bowser50
33
Jul 21, 2013 06:33 PM
banana
Dec 1, 2009 11:44 PM
waam
21
Jan 2, 2003 07:28 PM
