Folks with G56's
Old Jun 24, 2010 | 04:01 PM
Tate's Avatar
Folks with G56's
Wondering if I could trouble you guys for a measurement. I need to know what the depth of the engine adapter is, from the engine block to the tranny bellhousing. I'm working on swapping a G56 into my 12v, and I'm getting a lot of mixed answers on what I need, so I may as well just start from scratch. This will be the first step in the puzzle. My tranny is out of an '06, so that would be preferable, but I can't see an '07 being much different.
Old Jun 25, 2010 | 10:01 PM
rich's Avatar
the nv5600bolts up to the 12v so the g56 will also. same size. al tho some have said something about a starter spacer.
Old Jun 26, 2010 | 09:27 PM
Tate's Avatar
The G56 also had the dual mass flywheel, which is where the complications start. AFAIK, due to the DMF, the input shaft is a bit shorter than that of the NV's. Crank spacers will work on some clutches, but not all, due to the disc to input shaft bearing retainer clearance. Bolt patterns are the same on the engine adapters, I was just curious if the depths were the same as well.
Old Jun 26, 2010 | 11:25 PM
rich's Avatar
you can get the flywheel to use in place of the crappy dm. its been awhile since i replaced mine but think its thicker then a regular flywheel. I would say if you get the flywheel for the dm replacement you shouldnt have any issues then
Shovelhead
Jul 29, 2003 06:35 PM
DixielandDelight
Jul 24, 2003 11:34 AM
PapaSmurf
Jul 10, 2003 10:58 PM
RATTLINRAM
Jun 11, 2003 05:22 PM
