Firestone Level-Rite Air shocks
Old Mar 20, 2009 | 09:57 AM
dehunter12's Avatar
I see that Firestone has a leveling air shock for the Dodge Ram HD. Has anyone tried these? If so what do you think, are they better then the conventional leveling kits?
Old Mar 20, 2009 | 10:05 AM
sallyman1's Avatar
i seen that also. i believe its called firestone ride rite. i know the rear shock/bag kit is model 2299 for our trucks. ill find the front #. i know it consists of a stock looking shock that has a built in air chamber. you can raise truck to whatever desired height....
Old Mar 20, 2009 | 10:11 AM
sallyman1's Avatar
i found it. right on the firestone ride rite site there is 2 kits for our 2003-2009s. #1004 for the front and #229 for the rear. the front is a shock u add air to.any1 ever try this?
Old Mar 20, 2009 | 03:07 PM
sallyman1's Avatar
any1 with info or feedback?
Old Mar 20, 2009 | 06:48 PM
hylander's Avatar
AIR BAG OR SHOCKS ? Only air shocks I ever used broke the shock mounts out of the frame when I hit a big hole.
Old Mar 20, 2009 | 07:08 PM
sallyman1's Avatar
wow. wer ethey firestone ride rite shocks #1004?
Old Mar 20, 2009 | 10:27 PM
.boB's Avatar
Air shocks have been around forever. Back in the 70's we used them to jack up the rear of a "hot rod". But, bad things happened, exactly as Hylander said. The shock mounts are not meant to support that much weight. It wasn't uncommon for the mounts to break. I wouldn't use air shocks on to anything to raise the ride height. You can use them to stiffen the ride a bit for better handeling. But not for raising ride height, or increasing pay load.
Old Mar 24, 2009 | 12:35 AM
BLACKBEAR's Avatar
I thank what you are talking about is the fire stone air bags that helps with heavy loads. They do a good job with heavy loads
Old Mar 24, 2009 | 01:48 PM
dehunter12's Avatar
Firestone has them on their website now, a new item for 2009. Myself and Sallyman1 were just wondering if anyone has used them on their 3rd Generation Dodge and how they compare to the normal leveling kits.
Old Mar 30, 2009 | 07:05 PM
redneckcb69's Avatar
i have them installed on my 2005 ram 3500 the work great i also had them on my 92 gmc 1500 it hauled a 29f fifth wheel kept it level very much improved the ride i would recommend them highly for your truck
Old Mar 30, 2009 | 07:28 PM
sallyman1's Avatar
i just bought the 2299 kit. i will install it myself. my only question is do i remove the rubber stopper under my frame rail? the jounce or whatever its called?
Old Mar 30, 2009 | 11:06 PM
_Adam_'s Avatar
The rubber jounce is bolted on. It is the easiest part of air bag installation.
kokalit
Jan 27, 2010 10:11 AM
Utundra
May 30, 2008 02:59 PM
Sixpack
Mar 27, 2006 08:19 PM
Fueling around
Sep 7, 2005 06:55 AM
03CTDCO
19
Mar 9, 2004 07:10 PM
