Fill Oil filter?
Old Apr 22, 2010 | 07:47 PM
Spooler's Avatar
If you are able to fill the filter due to mounting, always do it. If it is mounted sideways or upside down, you don't have much choice.
Old Apr 22, 2010 | 10:01 PM
megacabdad's Avatar
I'll second that.
Old Apr 22, 2010 | 10:09 PM
.boB's Avatar
Think about it. Most of you guys are pretty smart, so use your head. Oil goes from the pan, the pump, the filter, and then the rest of the engine. Any dead spaces in there will have to be filled before oil goes to the engine. That's a big filter. Why have a nearly 1 qt dead space if you can easily avoid it?
Old Apr 22, 2010 | 10:29 PM
Shorts's Avatar
On the sideways ones I filled the filter until the element was what I thought was saturated. Which was I filled it up until the filter was topped off and quick drinking oil. Then I poured the oil back out into the bottle to at least the level of angle at which the filter was to be applied. Then I used my cat-like reflexes and master skill to screw the filter on without spilling a drop.
My thinking behind this was at the very least there was some oil in the filter and soaked in the element to be pulled through until the filter filled up completely. It did take an extra few minutes and probably sounds batty but just something I did. Not a clue if it was actually preventative, no skin off my teeth to do it.
I've never had anything with the filter upside down.
Old Apr 22, 2010 | 11:22 PM
Dieseljunkie's Avatar
When I change the oil myself, I pre-fill.. The last change, I had a friend that owns an auto repair shop do it for me, and I have no idea if he pre-filled or not, but the truck is still running, so I don't worry about it.
Old Apr 23, 2010 | 08:13 AM
Lost Lake's Avatar
Couldn't have said it better. Why not get rid of 1 quart of bearing seizing air and replace it with fresh cool oil? I fill mine.
Old Apr 23, 2010 | 08:55 AM
spoolinup's Avatar
I don't think I could change my oil with out filling the filter. But I'm **** that way
Old Apr 23, 2010 | 02:53 PM
15 Digger's Avatar
Originally Posted by Shorts
So if the FOD doesn't fall in the filter it can fall into the engine through the fill hole
Oh no! How do we get the oil out of the jug?!??!!!?!?????? Just be careful and thorough taking the foil off.
I've always prefilled the filter.
It drains through larger holes to the pan then is filtered before it get to small oil ports.
Old Apr 23, 2010 | 10:49 PM
hector's Avatar
If I remember correctly.. It says or (shows A symbol) on the fleetguard filter to fill the filter
Old Apr 24, 2010 | 08:25 AM
NavyDood's Avatar
I always prefill. If you have the time, fill through the small holes, not the center. Small holes are supply and big center hole is return.
Old Apr 24, 2010 | 08:32 AM
trainermg's Avatar
All it does is take just little bit longer to get oil presure on the first start .I dont thinfk it hurts any thing!
Old Apr 24, 2010 | 08:54 AM
gsqhtr's Avatar
I always Pre-fill mine.
Old Apr 24, 2010 | 09:31 AM
billie's Avatar
If it was a big deal, no filter would be mounted horizontal or upside down on a diesel or any motor.
Good idea to pre-fill, sure, simply makes sense.
Enough to worry about if you don't, I don't think so.
Old Apr 24, 2010 | 09:51 AM
BLACKBEAR's Avatar
Originally Posted by 15 Digger
Watch for debris, there was some info from Cummins about engine failures because a piece of foil or something that got into filter when filling ended up plugging small oil hole in engine causing engine failure. After hearing that it's dry filter for me. When you change oil on warm engine the parts will still have oil on them and the pressure comes up quick.
Out of thousand's of people that fill their oil filters one dummy makes a bad fill and this is should stop every one? I DON;T think SO ..I have done this from the age of 13 I am 70 and still fill my filters.
Old Apr 24, 2010 | 10:06 AM
CD in NM's Avatar
I pre-fill mine, always have, always will. It just makes sense to do it right. My manual also says to pre-fill the filter.
C
