Extension tool to reach Oil Pan bolts
I noticed I have a tiny bit of moisture around the Center bolt that is up between the back of the oil pan and the transmission... I have the Manual trans. I think all it needs is a little Snug down... I have the correct ratchet just wondering if they made a 6" or so extension so I can reach up there and snug it down a bit... Thanks for the help... It's real small amount, not even enough to start thinking of making a single drop...
Yes, it's that Little Drive. Anyway, I cleaned it all up and will watch it, not even enough to worry about. And I know you can over torq and cause more leakage.. LOLOL So I will watch it for a while. Could you put a piece of cloth over the breather and zip tie it down to test the Idea it might have come from the breather?
jelly
Jul 6, 2004 04:39 PM
