Engine?
Old May 7, 2009 | 08:14 AM
huck25's Avatar
Engine?
Hey guys quick question, can I use an 03 block in my 05 truck? Meaning can I transfer my parts to an 03 block. Might be able to get one cheaper than fixing my 05 block. tia!
Old May 7, 2009 | 01:23 PM
huck25's Avatar
bump????? ANYBODY?????
Old May 7, 2009 | 01:26 PM
cody459's Avatar
What do you need to get done to your 05' block that your wanting go with an 03' block. Lets start there.
Old May 7, 2009 | 01:36 PM
huck25's Avatar
#5 piston gone. Not sure how bad, but there is excess blowby meaning exhaust coming out of the blowby tube. I was figuring if I could transfer things over it would cut down on down time in case my block is really bad.
Old May 7, 2009 | 01:48 PM
rich's Avatar
depends i know the injector spray pattern is different so the pistons mite be different
Old May 7, 2009 | 01:56 PM
cody459's Avatar
Went through the same problem on my 06'. When my turbo went it threw out #5 and #4 totally burnt them up. To machine and sleeve the block cost alittle under $400. Do you have an 03' block already are were you going to buy one? If you do have one I would call cummins and ask them about a swap.
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
apache
Feb 22, 2004 05:27 PM
