EGT temps while towing
Old Jul 7, 2009 | 12:02 PM
AH64ID's Avatar
Originally Posted by stock03
I had the VA off the entire trip and it still did it. It's a vicous cycle: The EGT's hit 1100, the truck slows down a little bit, and then the boost drops, which results in EGT hitting 1100 again...That's when I have to press the throttle. Luckily this only happens going up steep hills (CA has some really steep grades!)
Really interesting, but that doesn't sounds normal.
Old Jul 7, 2009 | 12:04 PM
MikeyB's Avatar
I would completely remove the VA and see if it still does it.
Do you have a boost gauge?
MikeyB
Old Jul 7, 2009 | 09:19 PM
RiverRat2's Avatar
Originally Posted by ah64id
1450 is for 04.5+ trucks, and yes it is very easy to get there with stock fueling on the 04.5+ trucks.
Couldn't tell ya, maybe its your VA, or something with the CC.. but the ECM has no way to monitor EGT.
So could one infer,,, installing an aftermarket fuel pump and an adjustable boost elbow will drop my EGT's when towing the Race car hauler,,,, who's a fat/long/tall pig weighing in at 14.8K+??????? on good hills I commonly spike to 1400+ until I Down shift to the 5 hole and spin the moto/boost up a bit..
Old Jul 7, 2009 | 10:00 PM
stock03's Avatar
MikeyB
Yup, I have a boost gauge. Does the VA have a boost fooler? I'll remove it before my next trip and see what happens.
Old Jul 7, 2009 | 10:02 PM
stock03's Avatar
Originally Posted by RiverRat2
So are you saying,,, installing an aftermarket fuel pump and an adjustable boost elbow will drop my EGT's when towing the Race car hauler,,,, who's a fat/long/tall pig weighing in at 14.8K+??????? on good hills I commonly spike to 1400+ until I Down shift to the 5 hole and spin the moto/boost up a bit..
I do the same now. 5th gear for the hills is the only way my boost stays up (sometimes over 40#) and my EGT's stay in check.
Old Jul 7, 2009 | 11:02 PM
sallyman1's Avatar
i tow a 10,000 lb 34 foot tt. i see 900-1000F on level ground. i see 1200 ish going up hills. my water temp runs between 190-215 F and my tranny runs between 160-215 F.... i have a goerend tiple disc converter.
Old Jul 8, 2009 | 06:55 AM
MikeyB's Avatar
Yes, I believe the VA does boost fooling.
MikeyB
Old Jul 8, 2009 | 09:13 AM
AH64ID's Avatar
What are you doing for fueling? If stock then your fuel pump is more than fine.
Adjustable boost elbows can work on the 04.5+, but are trickier as the WG is electronic. Honestly get a Smarty Jr and set it on SW1.
Old Jul 8, 2009 | 10:57 PM
RiverRat2's Avatar
are you running the amsoil ATF in your tranny????????
Yes the fueling is stock, turbo stock, bought the 2 micron universal mount GDP canister,,, want to install between Factory filter and CP3,,,,,,have been running Wix,,, in FFC,,, just switched to Baldwin drop ins,,,,
I think you are right,,,, The Smarty Jr Revo May just be the ticket,,,
I can leave the MP3 turned up when towing the 15K Toyhauler but it eats the fuel!!!!!!!!! LOLOL,,, have to sneak up on the RPM /speed to keep mileage/EGT's in check LOLOL!!!! easier just to turn it down and lay the wood to it!!!!!!
Funny before I got the guage pack,,,, I never knew I was in the EGT danger zone!!!!!
I have got as good as 11-12 MPG on flat ground @ 1900RPM 58-60 MPH
Old Jul 9, 2009 | 12:03 PM
AH64ID's Avatar
No, I run the Syncromesh Tranny fluid, the NV5600 doesn't use ATF.
Good call on ditching the WIX, it doesn't meet OE spec.
You would be very happy with the SJR.
Old Jul 9, 2009 | 12:11 PM
RiverRat2's Avatar
Did you pull the the hard line from the FFC to the CP3 to install the GDP 2micron filter???? is your fueling stock or are you running an aftermarket pump???
Old Jul 9, 2009 | 12:44 PM
AH64ID's Avatar
Yes, I have the full big line kit.
Yes, stock fueling with Smarty Jr timing. Stock lift pump.
Old Jul 9, 2009 | 12:47 PM
RiverRat2's Avatar
Cool
Cool!!!!!!!
Old Jul 9, 2009 | 11:46 PM
offroad00's Avatar
Back to my original post, the boost elbow showed up today so we installed it and it dropped the EGT a good 200 degF during normal driving and allowed the boost to go over 30 PSI easy. Will have to see what it does under a heavy load next time we have it out. Thx for the advice.
Old Jul 10, 2009 | 06:59 AM
RiverRat2's Avatar
Good on ya!!!! sounds like MikeyB and the boyz figgerd it out for yas,,,,, This is a neat site,,, way to go guys!!!!!!
Give us a report after towing!!!!!!
