Dumb question??
Old Jun 21, 2009 | 11:48 AM
cody459's Avatar
Dumb question??
I'm needing to replace the lines going to the accumulater/drier, whats the proper way of removing them.
Old Jun 22, 2009 | 07:46 AM
1-2-3's Avatar
Just a plain ole guy
There is a tool made for separating the ac lines. It's a wrap around plastic sleeve that slips under a spring to release the grip it has on the outside of the inserted line. A set can be had at just about any auto parts store for about $9.99. After using one, I think one could cut a strip out of a plastic milk carton and slide it into the fitting and do the same thing. Don't force it or you will damage the connector. Once you get one apart you will be able to see the inside and can see how simple it works.
calvin
Jan 4, 2003 10:41 AM
TPilaske
Jan 1, 2003 12:57 PM
Push Rod
Dec 31, 2002 10:46 AM
wheels
Dec 22, 2002 10:49 PM
bigbaddiesel
Dec 7, 2002 07:40 PM
