dumb question
Old Mar 31, 2009 | 01:58 AM
choppers555's Avatar
dumb question
Do diesel engines have timing belts? i know on a gas engine's the timing goes off the spark, but is there timing with glo plug?
Old Mar 31, 2009 | 02:48 AM
Zeus1987's Avatar
usually not. I think the glo plugs only come on when you are about to start it. once the engine is running you shouldn't need them again unless it is really cold out. thankfully our cummins has neither
Old Mar 31, 2009 | 03:32 AM
madhat's Avatar
Administrator/Jarhead
Our trucks do not have timing chains, but have gears that mesh for timing. I believe that timing is also controlled by the ECM through the injectors.
We do not have glow plugs, either. In the CR engine, we use a grid heater that is at the bottom of the intake horn to heat the intake air. It is controlled by the ECM also, and uses temperature to determine when it comes on.
Not a dumb question. I had to look up the timing one. Are you having a problem?
Old Apr 9, 2009 | 12:31 AM
no not having a problem just curious because i know i regular cars you need to change them about every 100k or so. but anyways sweet learned two things . thanks guys
Old Apr 9, 2009 | 03:27 AM
madhat's Avatar
Just ask...
calvin
Jan 4, 2003 10:41 AM
TPilaske
Jan 1, 2003 12:57 PM
Push Rod
Dec 31, 2002 10:46 AM
wheels
Dec 22, 2002 10:49 PM
bigbaddiesel
Dec 7, 2002 07:40 PM
